SteamingEvery machine has one or two 'why did they do that?' With the Achille, that happens to be the steam wand, or more specifically the tip. The steam wand itself works wonderfully. It has ball mount so it can be articulated in any direction or angle the user could ever want. The diameter of the steam tube is a little small but well matched to the machine's steaming capacity. It produces a high velocity steam and lots of it:
The velocity of the steam will produce an absolutely wicked turbulence in the pitcher which makes wonderful wet silky microfoam. And then they do this:
Why would you equip it with a frothing aid? I have never been a fan of froth aid devices, but the one on the Achille is not too bad. Unlike most of its contemporaries, this one is constructed of stainless steel with a plastic insert. As with most of these devices, the key is a small air intake on the wand. That air intake injects air into the milk producing foam. If you can surf that hole on the milk's surface, you can control the amount of air injected and produce decent microfoam. The problem is that the froth aid tip is long and the pin-sized air hole is near the top of the froth aid attachment. That means you either need to be frothing a lot of milk, or a little milk in a tall and narrow pitcher.
If you plug the hole, then you can use the froth aid as you would any other steam wand and surf the tip. If you remove the froth aid device you are left with a single hole steam wand. Unfortunately, that wand is not long enough to use for steaming unless you are using a shallow pitcher.
I discussed the froth aid device with Todd Salzman at Whole Latte Love to see if there were any other options. He sent me the frothing attachment from another machine which uses a longer inner tube. I removed the outer shell and just used the inner sheath as an extension. I can produce wonderful microfoam with the machine, but this is a Band-Aid fix at best.
The Achille really soars as an espresso machine. Gaggia has designed espresso capability that's worthy of the most demanding aficionado, but coupled it with a frothing aid meant for newbies. The price point of the Achille clearly targets the serious espresso hound. Why would you hamper it with a frothing aid? In my view, steam wands are not expensive and Gaggia / Whole Latte Love would be well advised to provide a drop-in replacement option that would compare favorably out of the box with less expensive levers like the Elektra Microcasa a Leva that boast legendary microfoaming ease.
NOTE: Steam heating performance numbers will be included in the final Buyer's Guide.
