maximatica wrote:another_jim wrote: for naked pfs, the moment the tigerstriping ends, rather than a few seconds later when the pour gets translucent.
Hi Jim,
Is there a readily available NPF for the Semi?
No, I'm using the Rancilio bottomless that Chris sells for the E61s, it needs a light ear filing (about 10 strokes fore and aft) and is a bit thin so goes to about 4 o'clock) but it works fine. The Elektra PF is massive, and way too pretty to chop
So glad you brought my attention back to the one that probably fits my needs the most; I like single cappys about 99% of the time and would like to drop the audiophilia aspect of the espresso endeavor. I'd like to buy something and just go with it. My tendencies to monkey around are aroused by temp control and such and I have other things to spend my time on.
M./
I think this thought is going around. This thread is turning into two articles, a review of the Elektra and a meditation on pursuing the godshot. If we're at the point of seriously considering $4500 machines, we're also at the point were I can add around 15 separate PID control loops to the Tea for the same money (I'm not sure anyone can figure out a use for that many!). I think we're seeing the birth of the hotrodded home-espresso machine, and "my shot can leave your shot in the dust" type bragging. Obviously, this means that no actual machine will work -- the hotrod will always be a bench full of interconnected parts.
I don't really want to opt out of fun like this, but I do need something to drink while the hotrod is up on blocks. Also, hotrodded home machines are unlikely to evoke the romance of espresso. So I figured the Elektra was by far the best antidote or balance to all this meshugas.
On the noise. The Elektra is now quieter than my Tea, which has developed the same series of sympathetic buzzes as your Millenium and whose rubber pump mount has rotted. However, I doubt it's quieter than a brand new one. The pump is screwed into the base with a rubber pad, and the braided hose is a good vibration damper compared to hard pipe. The noise is mostly from the pump, not from sympathetic vibration. If you are plumbing it in, it's no effort to take out the pump and either move it under a counter or replace it with a rotary. I'm set up next to a sink, and I like the machine being mobile, so I doubt I'll go this route.
I am finding some restrictions on my shots because of the high pressure (mainly overextracted notes in the long aftertaste); so I will add an OPV and give the how tos (to put this in perspective -- it not nearly as bad as the 11 bar factory set vibe E61 boxes). I've run into no temperature control problems despite its loose repeatability, a shorter or longer flush does the trick for sour or bitter respectively.
