by another_jim on Fri Nov 21, 2008 7:52 pm
All the Elektra home machines are made of marine brass. The surfaces are plated with chrome, copper, or a shiny brass (I'm not sure about the last part, this may just be the actual building material polished), and finally clear coated with a polymer similar to the finish on cars (you can restore scratches by using an automotive clear coat scratch remover or filler). This is a very beautiful finish, but it's not for the ages. In particular, the plating will probably start to peel in a ten to fifteen years or so. This can also be fixed at an automobile or motorcycle shop.
It is a gorgeous machine, it makes very good espresso, but it is not a tank.
PS: My Yaeger stat seems to be doing better than the Cemes or Maters too. All the innards do better if you don't run the machine 24/7, but put it on a timer instead.
PPS: What this machine has done is change one of my beliefs about home espresso machines. One does not need a 50 pound E61 box, or a 100 pound single grouper, for top notch espresso at home. It is possible to build very small machines, no larger or heavier than regular home espresso machines, like the Elektra Semi and the DC Mini, that pull state of the art espresso.
