This project started when I managed to score a 2-group Nuova Simonelli machine off of Craigslist for a ridiculously low price. However, the beast is absolutely huge, and when I brought it home my wife took one look at it and said something to the effect of "Nice machine. We're not keeping it." Considering the size of our kitchen, I think she was being more than reasonable
My plan was to clean it up and sell it to a good home, but then I got to thinking (never a good idea
My design is (I think) a very simple one. I will have two boilers, each with an inlet near the bottom of the tank and an outlet near the top (plus misc. fittings for heat elements, thermoprobes, safety valves, etc). The brew boiler is connected directly to the water inlet pipe, which, due to the bypass valve on my procon pump, puts it permanently under mains pressure. There will be a manual valve for the steam boiler (to keep things simple, I do not plan to have an autofill circuit). The outlet on the brew boiler goes to a tee, one direction to the group, the other to a hot water tap. The outlet on the steam boiler goes, you guessed it, to the steam wand.
As I see it, the advantages of having the brew boiler pressurized are
1) Simple hot water tap design (just turn the valve knob, no need for pump activation)
and
2) Easy to build in preinfusion by adding a delay circuit to the pump activation
I could not think of any downside, but perhaps I am missing something... i.e. anyone see any safety issues or design flaws with this setup?
The idea of having the brew boiler pressurized is not my own - in fact the heat exchangers on the Nuova (there is one for the groups and one for the hot water tap) feature such a design.
A few comments on the Nuova Simonelli machine:
The grouphead is a saturated type design - it is in direct contact with the boiler and hot water flows through it. This makes it an ideal candidate for a dual boiler setup, but I was a little surprised to see it on an HX machine. This tells me that either this machine would have needed a tonne of flushing to bring it down to temp after sitting (the HX is something like 600ml) or it radiates a lot of heat to the environment to keep it near brew temp. This isn't a big deal to me as I plan on insulating the group anyways. Aesthetics aside, it seems to me that having an uninsulated group head on a dual boiler machine is a design flaw if temp. stability is the absolute goal. For me, the Nuova group is nothing special to look at, unlike the LM or E61 groups, so I am quite happy to cover it up.
As for my boilers, I plan on getting some large diameter stainless steel tubing, and having end plates and pipe nipples welded on. I will also add on a neck and flange for the group. The total cost shouldn't be too high, but this is the part that makes me the most nervous. Am I putting myself at serious risk with such a boiler? i.e. if the joints fail will I have a steam bomb blast or a gentle hiss?
My final question has to do with heating elements. I sourced some nice stainless steel screw in cartridge type elements at mcmaster.com, but they are a little pricey (especially since I need two of them). They also sell screw-in water heater elements for considerably less. However, these elements are zinc plated and I am not sure what the flange is made of. Anyone have any comments on the suitability of these elements? As a partial compromise I was thinking of using the stainless steel element for the brew boiler, and the water heater element for the steam boiler, but I am worried about the flange rusting.
There were also a bunch of appropriate elements made of Incoloy, but I am not familiar with this material. Is it food safe? A cursory web search showed it in use for fat fryers, but that is a totally different environment than hot water.
Anyways, I appreciate any advice (or smacks in the head, if necessary) and I will keep posting my progress (or lack of it)
-Brad
