Brew temperature test equipment
Want to talk espresso but not sure which forum? If so, this is the right one.
Link to "Brew temperature test equipment"by King Seven on Sun Jan 08, 2006 10:16 am
Apart from the Scace device, what do people recommend by the way of thermometers/loggers/software etc?
And where is good to buy it all from?
Thanks,
James
King Seven
Re: Brew temp test equipment
Link to "Brew temperature test equipment"by Ken Fox on Sun Jan 08, 2006 12:36 pm
King Seven wrote:Apart from the Scace device, what do people recommend by the way of thermometers/loggers/software etc?
Thanks,
James
You should check out Jim Schulman's posts in the Home brew temp thread below for what he would do; he favors a modified Schomer basket with a cheap digital thermometer.
What I would recommend is getting a cheap to moderately priced digital thermometer and a thin K-type thermocouple (like 30 gauge) that can be secured with the group screw; you may have to mount it either below or above the group screen depending on your machine type. Barry Jarrett has posted a picture here on HB of his arrangement using this technique; I think you can find it by searching HB posts. It is somewhere in the Scace Thermofilter thread on "The Bench" forum.
This thermocouple, so mounted, will last for a period of time and then have to be discarded. I think that this method will give more repeatable results than what Jim has suggested, although there will be error introduced by the inexpensive digital thermometer.
ken
Ken Fox
Link to "Brew temperature test equipment"by HB on Wed Jan 11, 2006 8:11 am
I have the Fluke model 54 II from Tequipment.net (shop around for prices, they vary considerably). It has two input channels and datalogging. The real ticker about the Flukes is that FlukeView Forms software is required to download data off the meter using infrared, another $150. Omega offers their own in-house thermometers, though the reviews I've read vary from "great deal!" to "pain in the butt interface!"
I ordered thermocouples from Omega, 5SC series, 5SC-TT-36-36 (five pack, mini connection, teflon insulation, type T, 36 gauge, 36" long). You can save money by getting the wire / connectors and making the TCs yourself too (I was lazy and ordered the prefabs).
Link to "Brew temperature test equipment"by malachi on Wed Jan 11, 2006 11:42 am
Fluke 54, Scace.
If you're going to get serious, invest in a datalogger.
malachi
Thermoworks Digi-Sense DuaLogR Thermocouple Logging Thermo
Link to "Brew temperature test equipment"by miKe mcKoffee on Thu Jan 12, 2006 8:07 pm
I know many people use the Fluke 54. Anyone have any experience with the Thermoworks Digi-Sense DuaLogR Thermocouple Logging Thermometer? Click Here Specs look very similar except it can log 1000 instead of 500 readings, doesn't offer "software" just RS232 interface for use with terminal program.
aka Mike McGinness
www.norwestcoffee.com
miKe mcKoffee
Link to "Brew temperature test equipment"by Balthazar_B on Thu Jan 12, 2006 8:51 pm
There are also these devices, which have been brought up before:
http://www.omega.com/ppt/pptsc.asp?ref=HH506A_HH506RA
Anyone have experience with Omega dataloggers?
- John
Balthazar_B
Link to "Brew temperature test equipment"by miKe mcKoffee on Thu Jan 12, 2006 8:56 pm
Balthazar_B wrote:There are also these devices, which have been brought up before:
No experience but I looked at those and thought the "128 Samples with Real-Time Data" would be too limiting.
aka Mike McGinness
miKe mcKoffee
Link to "Brew temperature test equipment"by Balthazar_B on Thu Jan 12, 2006 9:34 pm
miKe mcKoffee wrote:No experience but I looked at those and thought the "128 Samples with Real-Time Data" would be too limiting.
I believe that's its capacity for onboard saved data. If you're logging data, it looks like the device will do more:
"The OMEGA HH506A is a low cost, feature-packed,
portable, digital thermometer that measures K, J, R, S, T, E
and N thermocouples. The unit has datalogging capacity in
the save mode of 128 samples with time stamp via pressing
the save button. In the datalogging mode up to 1024 records
may be logged at an interval set from 1 second to 23 hr/59
min/59 sec. Data is stored in 16 groups of 64 records. Easy
to use set-up instructions allow the user to measure a broad
range of T/Cs, MAX/MIN, AVG, REL, Hold Function, T1/T2.
The HH506RA has the HH506A features plus it includes an
RS232 interface with Windows software."
Of course, you could get a Fluke thermologger instead, for the price of about 3 of these :) .
- John
Balthazar_B
Link to "Brew temperature test equipment"by miKe mcKoffee on Thu Jan 12, 2006 10:16 pm
Actually I was leaning towards the Thermoworks for about 2.8 times more. :D However, I missed that information you posted about datalogging mode up to 1024 records for the OMEGA, so thanks. :!: Sounds worth looking into further. Need to find out exactly what they mean by 16 "sets" of 64 records. Whether it just means a continous datalogging is broken up into separate record sets or if each event limited to 64 records with total of 16 isolated sessions possible.
aka Mike McGinness
miKe mcKoffee
Link to "Brew temperature test equipment"by gscace on Fri Jan 13, 2006 10:29 am
I use a Fluke meter when I just wanna look at the number and don't care about logging. I use a picotech TC-08 8 channel thermocouple datalogger for logging. Picotech is an English company. If you're based in the US, Swangate International is a good source. The TC-08 is nice because you can do multiple groups at once, and also log things like boiler and group temps.
I have a project envisioned that's gonna require all 8 channels.
-Greg
gscace
Link to "Brew temperature test equipment"by Balthazar_B on Fri Jan 13, 2006 10:34 am
gscace wrote:I have a project envisioned that's gonna require all 8 channels.
-Greg
8 channels???!!?? Is one of those from a thermosensor under your tongue? :)
- John
Balthazar_B
Link to "Brew temperature test equipment"by lennoncs on Fri Jan 13, 2006 1:07 pm
Balthazar_B wrote:8 channels???!!?? Is one of those from a thermosensor under your tongue? :)
In the world of dataloggers 8ch is kinda the starting point, I regularly use 10-20 channels on the home projects and 200-300 channels on systems at work.
You need to keep in mind that temperture is not the only thing thatis measured.
Sean
lennoncs
Link to "Brew temperature test equipment"by lennoncs on Fri Jan 13, 2006 1:09 pm
You need to keep in mind that temperature is not the only thing that is measured.
Sean
lennoncs
Link to "Brew temperature test equipment"by HB on Fri Jan 13, 2006 1:28 pm
lennoncs wrote:You need to keep in mind that temperature is not the only thing that is measured.
For those who are reading this and thinking "OK, like what?", the epilogue of the Buyer's Guide to the Expobar Brewtus shows one example:
Although I've not rigged something as fancy as this, it's not hard to imagine that knowing precisely when the pump was engaged, heating element turned on, or solenoid X closed would give you a better picture of the system dynamic (not to say that it doesn't boggle my mind too :shock:).
Link to "Brew temperature test equipment"by DavidMLewis on Mon Jan 16, 2006 9:19 am
miKe mcKoffee wrote:Actually I was leaning towards the Thermoworks for about 2.8 times more. :D However, I missed that information you posted about datalogging mode up to 1024 records for the OMEGA, so thanks. :!: Sounds worth looking into further. Need to find out exactly what they mean by 16 "sets" of 64 records. Whether it just means a continous datalogging is broken up into separate record sets or if each event limited to 64 records with total of 16 isolated sessions possible.
Hi Mike,
At the end of the 64 records it rolls over into the next section. With a logging frequency of 1 sample/s, there's no gap. With a frequency of one sample every 2 seconds, there seems to be a three-second gap in the time stamps. I've reverse-engineered the protocol for my own use on a Mac, and have a little Python code that gets the input using a commercial USB/serial driver and massages it appropriately. I'll send them to anybody who asks. The supplied Windows software is cumbersome and buggy.
Best,
David
DavidMLewis
Link to "Brew temperature test equipment"by barry on Mon Jan 16, 2006 6:32 pm
it's taken you long enough to get there... ;)
i'm using 6 on my 2-group right now, and i've used 8 several times on the 4-group.
i've even thought of getting a second TC08, because if i log all the machine data, then i don't have room for the portafilter data, too! :twisted:
barry
Link to "Brew temperature test equipment"by lennoncs on Mon Jan 16, 2006 9:05 pm
barry wrote:it's taken you long enough to get there... ;)
How are you guys measuring things like flow, volume, pressure, pump cycle and heater cycles?
It appears that the Picotech is only a thermocouple device.
Thanks
Sean
lennoncs
Link to "Brew temperature test equipment"by barry on Mon Jan 16, 2006 9:26 pm
nah, i need all those channels just for temp.
i haven't got 'round to pressure & flow yet.
barry
Link to "Brew temperature test equipment"by cannonfodder on Tue Jan 17, 2006 12:15 pm
And it even makes espresso... :wink:
cannonfodder
Link to "Brew temperature test equipment"by erics on Mon Jan 23, 2006 5:50 pm
Hi David -
Could you elaborate (a few lines) on your statement "The supplied Windows software is cumbersome and buggy."
Have you contacted Omega and gotten their input?
It sure looks like large "bang for the buck"
Much Thanks,
Eric S.
erics
Next
Return to Knockbox
