Basically it is a heat exchanger machine with the boiler (kettle) at brew temperature rather then steam temp. The ~2.5 liter kettle is only there to provide heat for the long HX tube coiled inside it.
Here are the original drawings and a few pictures of the functioning machine-
The pump and manual pressure valve are off to the left, and the PID and electromagnetic relay are off to the right.
A few technical details:
- Group from Gaggia Espresso
2.5 liter galvanized steel kettle
1000W heating element
5 meters of ID6mm nylon tubing (rated at 120C, 3.0Mpa)
no-name vibe pump
This afternoon I got my grind and dose right and had the most extrordinary ristretto I've ever had... no exaggeration... the first sip was like a sunrise, gone in a moment then a slow wash of... no words for that flavor! The aftertaste wasn't pleasant, perhaps the temp was a bit low or there was a bad bean...
Here is a video of the shot. You can see the pressure up in the left hand corner, I held it at about 9bar. It was 15.5g of a mix of Colombian, mokha, and mandheling (the last of my greens!) pulled at 100C (un-calibrated) in a CMA double basket. (Warning- the vibe pump makes a racket... turn your volume down!)
And the shot. Probably not much crema by the standards of the folks here, but it looks good to my lever-trained eye!
Enjoy!
Henry
