Cutting to the chase, if you are attempting to attain a tight level of temperature control in your boiler with a PID system or other electronic control, the effectiveness of your efforts will be impacted by the fill level of your boiler. To the extent that my observations are transferable to other machine configurations, you will probably find that the lower the boiler fill level (within the acceptable range for your machine), the more tight the control will be that you will observe in both consecutive shot series and in random "walk up" shots. The boiler fill level will also probably impact the median shot temperatures you obtain for any given boiler temperature setting. That's the summary statement, and if you are not interested in how I went about studying this you may wish to jump down to the graphs (below) which illustrate my observations.
BACKGROUND
I've written extensively about my two Cimbali Junior Espresso Machines, which I often use as a sort of "experimental testbed" for studying various issues involving coffee and espresso production. In addition to providing my daily caffeine jolt, I've used these machines together a number of times in simultaneous blind tasting experiments, where shots are pulled at the same time on both machines, and presented in double blind fashion to a taster who is asked to pick preferences along various parameters. These machines have been used recently in a grinder experiment to be written up as part of the Titan Grinder Project, and for other tasting studies such as in the frozen coffee article published here, plus various comparisons attempting to study if there is a difference between vibratory pump and rotary pump operated machines.
It has been key in these studies to try to equalize shot parameters, including shot temperatures, as much as is possible, so as to make the output of the two machines as close as can be accomplished, even though all studies have had a balanced design which accounts for the fact that there are two somewhat different espresso machines being used.
In the process of trying to get the machines to have extraction parameters that are very similar, I've chosen to replace the original pressurestat temperature control with the installation of PIDs, a form of electronic temperature control using (in this case) thermocouples in the boilers, an electronic fuzzy logic PID controller, plus the required solid state relays.
Unfortunately, tight temperature control on these machines has been somewhat of a moving target requiring me to calibrate them frequently and to change the boiler temperature with some frequency in order to attain the same shot temperatures as measured by a Scace Thermofilter ("Scace Device") and datalogger. Every significant study I have done has been preceded by several hours required to get both machines calibrated to the same brew temperatures, as I have seen significant temperature "drift" over time in spite of constant or nearly constant boiler temperatures, controlled by the PID.
What on earth was going on? There was clearly an "elephant in the room," but I just couldn't see it. The factor I was missing was that relatively small differences in boiler fill level, in a heat exchanger machine, can cause large differences in temperature performance of an otherwise temperature stable machine. This may not explain all of the temperature variation I was seeing, but I believe that it does explain the vast majority of it. A couple of days ago as I was getting ready to do the above mentioned Titan Grinder Project experimentation, I realized the possibility that changes in boiler fill levels were causing the temperature drift I was seeing. Therefore, I set out to explore this issue and hope that what I have found will be of use to others contemplating the installation (or fine tuning) of electronic temperature control in the boilers of their espresso machines.
I chose to do this study with my older, vibratory pump, pourover, Cimbali Junior "S" machine, circa 1995. It has a 2.5 liter boiler which is manually filled via a pump actuated by a button on the front underpanel; the boiler level can be viewed by a sight glass in the front panel of the machine:
Although the printing on the front panel is partly worn off, one can see that there are markings for maximum and minimum fill levels. I have filled the boiler up to the "maximum" level, and found that there are approximately 625ml (~21oz) of water separating the "max" and "min" levels shown on the sight glass, and about 12.5 oz (375ml) between the "max" line and the midpoint between the "max" and "min" lines shown, with the remaining ~8.5oz/ 250ml between the midpoint and the "min" marking. One can drain a little more than 8 oz./200ml out of the water wand from the machine when the boiler is full of hot water and the level is at the "min" point. Even after all of the water drains passively out of the water wand from the hot boiler, there is still quite a bit of water remaining in the boiler, which would be drained only by opening the drain plug at the very bottom of the boiler.
The above detail is given here only to give an idea of how much water I am talking about separating these observable levels of water fill, in this boiler with a stated capacity of 2.5 liters. Of course, no espresso machine boiler is ever normally filled to anything close to the stated capacity.
RESULTS
Now that I have set the stage for the tests I ran yesterday, I will show you what was the impact of boiler filling on shot temperature performance in this machine, both in consecutive shot series and in random "walk-up" shots. I chose a temperature that was usable at "low boiler fill," e.g. at the "min" level on the sight glass. Here are the results I got from consecutive shots and from random walk up shots:
(click image to enlarge)
and
The boiler was then filled further, to the mid point on the sight glass, which by measurement represented an additional ~250ml. At the mid level of boiler fill, the level I have used consistently in the past, this is what we get for measured brew water (shot) temperatures in both consecutive shots and in random walk-up shots:
and
Finally, at the "maximum" boiler fill level, representing an additional ~375ml above the "mid-level," one observes this behavior in shot temperatures:
and
DISCUSSION
If you are attempting to tightly control the temperature of brew water in an espresso machine, with electronic temperature control in the boiler, you will observe different results depending upon the boiler fill level. Within the limits of acceptable fill for your machine, you will probably get your tightest temperature control and the most rapid recovery in shot series, by keeping the fill at the lower end of the range. This is not surprising since it requires less energy to heat a volume of steam than a volume of liquid water. If you are experiencing variability in observed shot temperatures that cannot be accounted for by other factors, then experiment with boiler fill levels in your machine. You will probably find that the fill level is a very important factor in the degree of temperature stability you are able to achieve.
ken
