by another_jim on Tue Nov 15, 2005 1:15 pm
If you have a bean or blend you know nothing about, by all means pick a temp suitable to the roast color. If you know about the acidity and sweetness of the blend, use that info for your first shots. If you have a lot of highgrown, high acid coffees, you may want to start with a high temperature ristretto which will sweeten and mute the high end. The same advice for a low acid, low grown, dp would be very bad, yielding an intensely bitter, overextracted shot. For these, it's best to start cool and long.
But Chris is right about needing to experiment. A new coffee should be investigated at several temperatures and extraction ranges (ristretto to normale) to find the "sweet spot." If the taste has some complexity, there may be several sweet spots that accentuate one aspect or the other. If pressure weren't such a pita to change on most machines, I'd investigate that too.
