prettydeceextrap wrote:It is a basic culinary technique called a ganache - used to frost pastries or to make truffles. Just add a teaspoon or so of vegetable oil to your chocolate - be it a bar broken up into pieces or chocolate chips. Then microwave it (or heat it on the stove if you are sans microwave) for about 30 seconds, until the chocolate is just melting.
It's not advised to melt chocolate with microwave for taste and texture reasons, using bain-marie method would be the clever choice here. Also your description of ganache... uh! That's not ganache. Ganache is made with heavy whipping cream and couverture chocolate, if you reduce the amount of cream you get truffles, If you increase the amount and add peanutbutter or nutbutter you get cream chocolate that's suitable for spreading on bread etc etc
prettydeceextrap wrote:This would make things much much easier to do it this way. Buy some cream, whisk the hell out of it (sugar or not), and just add whipped cream on top instead. It would make layering easier. I think the way I remember the Bicerin was with foamed milk ... probably foamed cream ... making it a sort of half way point between froth and whipped cream. Anyway, like I said ... it would be delicious either way.
it's probably steamed half n half. In general people confuse milk and milk products so lets remember..
a) skim milk --> 1,5% fat
b) whole milk --> 3% fat (this ratio differs from country to country and brand to brand. Some label their whole milk 3,4% some label 3,1% and so on)
c) half n half --> 10-11% fat (50% milk + 50% cream blended)
d) cream --> 15-20% fat (still in liquid form but it's also suitable for whipping and gets thicker if you whip with an electric mixer but result is never too stiff)
e) heavy whipping cream --> 34-36% fat (you can easily whip without an electric mixer)
f) clotted cream (well at least turkish-english dictionary says so for "kaymak") --> 55% or more fat
prettydeceextrap wrote:I do not believe, however, that the trick to this is entirely in the chocolate, as I think a lot of it has to do with knowing how to layer things. It took me a while to learn how to layer cocktails - for instance - or to even learn how to properly pour foamed milk into my cappuccinos.
no matter what you do the one with higher density will sink bottom. With the help of extra ingredients you could try some tricks to change that order.. but with existing ingredients here chocolate will go bottom, either you'll pour chocolete over espresso and let it sink, or pour chocolate first and layer espresso over it.
