by boar_d_laze on Tue Aug 07, 2007 12:29 pm
I'm no expert on espresso making, but I play one on...
No, that's not what I meant. I'm no expert, but I've been using a Livia 90 for almost 20 years, so I do have some expertise when it comes to the Bezerra/Pasquini (BP). My experience gained at friends' houses, and from shopping for machines in Los Angeles (where there are a few with which to play) leads me to conclude that with vibe pump, pour-over prosumers, with a few exceptions, the obvious distinctions are appearance, price and secondary attributes such as steaming and hot water; but the quality of construction and components does count.
In these mid price levels ($500 - $1500) you're looking at machines which, after you've learned to adapt your techniques to the machines idiosyncrasies, when paired with a suitable grinder, are capable of producing usually good, and occasionally excellent coffee. If the big chain coffee houses usually pour 4s, most of yours will be 7s, with plenty of 8s, and once in a great while a WTF?! 10. You'll get the odd 3 or 4, too, but that's why there are sinks.
As you ascend the price ladder consistency and quality improve subtly. There are probably a few machines which are stinkers and don't justify their price. There are also a few which work a little above their price, and the Bezzera is one of them. Not a giant step. The Bezzera is close to the bottom of the "prosumer" price range. You expect less machine for $700 than for $1500, and you get it. It's reflected in the coffee. At the top and bottom of this price range the differences in the number of good cups is no longer subtle. FWIW, the B is not mechanically identical to the P. There are (or used to be) differences other than the casing having more to do with longevity and convenience than performance. I understand the brew path (boiler, heater, hx, group, etc.) is the same. Steam is good. Hot water not so much.
Considering the market generally, the Bezzera is more for the money than you'd expect, while the Pasquini has been superseded by price-point competitors and is less.
I've got no quibble with anything said by people who've actually used BPs. The people who market BP claim they're ready to start working 10 minutes after you've hit the switch. No. It takes around 30. At that point you can pull a couple of ounces through a clean portafilter to equalize temperatures. Wait a couple of minutes, pull an ounce into a demi-tasse, let the demi sit. Release the porta, fill it, tamp it, and lock it in. Empty the demi, and fill it with coffee. Watch the stream carefully for color changes, shut off the pump when the color lightens and the steam begins to exhibit translucence. Empty the porta and get ready for the next shot. If the machine has more than a couple of minutes between shots it will require pulling another blank shot.
It's already been said that Bezzerra/Pasquini baskets are not the best. Speaking of baskets, you'll pull sweeter coffee with better crema if you do not thoroughly rinse and clean the baskets between shots, but just reuse them as they come from the knock box. I'm pretty sure this has to do with back-pressure mimicking pre-infusion. After a couple of hours though you do have to clean as cooked-in oils start to announce their presence.
Backflush every 10 shots or so (every other day, for most of us), backflush with detergent every 150 (2X/month). Every or every other backflush with detergent remove the screen and dispersion block and thoroughly clean them. In 18 years (or whatever it's been), I've had to descale twice, replace the gasket twice, and replace the hot water valve once.
Bottom line: It's a good machine for the money, but there's no free lunch. If you can afford more, spend more, get more.
Rich
