Better espresso through Diedrich Home Roaster, or LM GS3?
Link to "Better espresso through Diedrich Home Roaster, or LM GS3?"by Dogshot on Fri Sep 15, 2006 9:37 pm
Now that Diedrich makes a home roaster, the ability to use pro-level equipment is now available to anyone interested in home roasting. Given that really high-quality coffees are becoming available in green, home-roasters will have the freedom to buy COE coffees when available and roast and consume them as desired.
How do you see your future investment in the quality of espresso in your home? Do you think that your ability to make great espresso would be improved more through a super-machine like the GS3, or through a pro-roaster like the Diedrich?
Going from a decent espresso machine to a GS3 should help the HB to get better, or at least more consistent results. I suspect that going from the typical HB's roaster (i-roast, SC/CO, Hottop) to a roaster like the Diedrich would give a bigger bump in overall results. As a bonus, I would hope that the Diedrich would be able to offer more consistent results than the i-roast/Hottp/SC/CO, thereby rewarding learning more quickly.
Mark
Dogshot
Re: Better espresso through Diedrich Home Roaster, or LM GS3?
Link to "Better espresso through Diedrich Home Roaster, or LM GS3?"by miKe mcKoffee on Fri Sep 15, 2006 10:36 pm
Dogshot wrote:Now that Diedrich makes a home roaster, the ability to use pro-level equipment is now available to anyone interested in home roasting.
Diedrich was seemingly following the lead of The San Fransican one pounder which has been available for quite some time and The US Roaster Corp's one pounder also preceded Diedrich's entry. Either of which gas roasters would offer greater profile control then Dietrich's 13.6A 110v offering from my research. That said based on my going on 6 years home roasting experience none of them are required to achieve home roasts comparable to about anything offered out there roasted commercially. Though they would do it in most excellent style and be easier to attain said excellent roasts repeatably!
Dogshot wrote:Given that really high-quality coffees are becoming available in green, home-roasters will have the freedom to buy COE coffees when available and roast and consume them as desired.
I don't see this as a recent happening either.
miKe mcKoffee
Link to "Better espresso through Diedrich Home Roaster, or LM GS3?"by another_jim on Fri Sep 15, 2006 10:38 pm
Sweet looking roaster. If you want to assure yourself that you've spent your way to good espresso, it and a GS3 should provide all the reassurance you'll ever need.
If you want more than reassurance; it's a slightly different story. Equipment at this level certainly has the durability you want, no matter how much you use it. On an entirely different plane, I much appreciate using the P1 popper over any of its successors, since it's built like an appliance and I don't need to replace it every 6 months. But all the poppers do a pro-level roast once they are hooked to a PID, a fan control, and custom designed and insulated roast chambers. Contrariwise. I have a hand mixer, a Braun, that works better than a Kitchenaid and Cuisinart combined, despite being a shoddily built gadget I have to replace every 6 months.
It comes down to this: Being beautifully and well built isn't the criterion of quality output; although such things are a pleasure to use. The key is that they can be used as tools, accepting fine variations in all the variables one needs to control. I have no idea at all if the Diedrich roasts like a scalpel or like a dulled parade ground sword; there's some feedback that the GS3 is a very workable machine, but even there, the full story will only emerge after owners have had months to play.
Finally, the biggest point of all. Buying a scalpel doesn't make you a surgeon; buying the Diedrich's won't make you a roaster. Spending 10 years roasting only espresso on a Diedrichs won't make you a particularly good roaster either, even for espresso. Lots of light roasting and cupping makes roasters; if the Diedrich's is good, it'lll keep up with the demands of that.
Of course, as far as I'm concerned, i hope you get the roaster; you'll be the guinea pig for the rest of us.
another_jim
Link to "Better espresso through Diedrich Home Roaster, or LM GS3?"by Ken Fox on Sat Sep 16, 2006 12:29 am
Dogshot wrote:Now that Diedrich makes a home roaster, the ability to use pro-level equipment is now available to anyone interested in home roasting. Given that really high-quality coffees are becoming available in green, home-roasters will have the freedom to buy COE coffees when available and roast and consume them as desired.
Mark
In answer to the first question, and what is implied by it, once one has a certain level of espresso equipment (for the sake of argument I'll put this level at a basic E61 home espressomaking box plus a very competent grinder, say the Mazzer Mini), increases in the quality of shots pulled will be minimal per each $1000 dollars additional expended. This is not to say that a GS3 wouldn't produce a larger proportion of very good to excellent shots with less effort -- presumably, it would, but an experienced home barista with the basic E61 box plus MM would do very well and have nothing to be ashamed of.
If one then takes the raw materials side of the equation, i.e. the coffee, using high quality beans recently and properly roasted will produce a HUGE benefit over lesser combinations such as great beans which are stale or mediocre beans which are fresh or any sort of bean that is over roasted or has other obvious flaws such as poor bean development (e.g. beans whose exterior is more well roasted than their interiors, something that could come from poor technique). The difference between bad and mediocre, mediocre and good, good and very good, or very good to excellent in the bean department will dwarf the differences between the output of a basic E61 and a GS3. So, beans are very important, in fact they are the very most important variable assuming one has at least decent equipment to work with (this discussion focuses on espresso and one could certainly make a very strong argument that a teakettle and a $2.50 Melita cone would allow great coffee production of another sort; one could also argue that a Silvia level machine would be more than adequate as the lower end espresso machine in the comparison although I'm not sure I would buy that, especially in the stock configuration).
But I digress :mrgreen:
These little enclosed roasters are to me the equivalent, in coffee terms, of the meticulous model train aficionado's perfect rendition of a Swiss village, complete with well manicured houses and a mockup version of the alps, maybe even Mont Blanc :P They are cutesy scale models of full scale roasters and they look very very cool! One could impress even that neighbor with the $100,000 Mercedes by giving him a garage tour with the roaster as the highlight!
In reality these things are too cute for their own good. I doubt that very many real roasters would be interested in them for their stated use, as sample roasters. They are way too expensive and the capacity is too large for real sample roasting. I doubt they sell very many, if any, of these into that market, to people really trying to make a living from coffee, a fairly low margin business.
Many here have seen pictures of my own modified sample roaster, an earlier model that used to be sold by Roaster's Exchange, aka US Roasting Corp or somesuch. It's not pretty and it does smoke up the garage somewhat in spite of it now being operated under a smoke hood. I would not recommend my own personal odyssey to anyone who wanted a cost-effective solution.
If I was seeking a roaster along the lines of those little "Lionel Train" type roasters referred to in this thread, I would instead look at 1kg, maybe 2kg, sized roasters as offered by some of the same players and some other ones such as Ambex. I doubt that one would pay all that much more for the bigger size, and one would get a real piece of commercial equipment with a real resale market should one change one's mind and want to get rid of it later.
I am assuming that any of these roasters, 1lb or larger, will competently roast coffee although I have no actual experience with any of them. Roasting with my own modified sample roaster is a highly labor intensive process and demands time and attention from the human behind the controls, just like an espresso machine, whether it be an Isomac or an LM.
ken
What, me worry?
Alfred E. Neuman, 1955
Ken Fox
Link to "Better espresso through Diedrich Home Roaster, or LM GS3?"by Dogshot on Sat Sep 16, 2006 7:34 pm
another_jim wrote:But all the poppers do a pro-level roast once they are hooked to a PID, a fan control, and custom designed and insulated roast chambers. ..I have no idea at all if the Diedrich roasts like a scalpel or like a dulled parade ground sword.
It certainly would be nice if the relatively simple and inexpensive home-roast solutions are every bit as good as what the biggest names in roasters can engineer. I'm in the process of putting together an SC/CO, and if that goes well, I plan to add a variac for a bit more control. But that's about as far as I can go as far as hacking or designing my own roaster.
another_jim wrote:Finally, the biggest point of all. Buying a scalpel doesn't make you a surgeon; buying the Diedrich's won't make you a roaster.
I'm not suggesting that equipment is a substitute for skill, in anything. But the two do complement one another. If a truck pulled into my driveway tomorrow and the driver offered to unload either a GS3 or a Diedrich, I'm pretty sure I would go with the roaster; and that's pretty much the only way I will get either one of those units. But I look forward to hearing more about both.
Mark
Dogshot
Link to "Better espresso through Diedrich Home Roaster, or LM GS3?"by Dogshot on Sat Sep 16, 2006 7:39 pm
Ken Fox wrote:These little enclosed roasters are to me the equivalent, in coffee terms, of the meticulous model train aficionado's perfect rendition of a Swiss village, complete with well manicured houses and a mockup version of the alps, maybe even Mont Blanc :P ...If I was seeking a roaster along the lines of those little "Lionel Train" type roasters referred to in this thread...
Thanks Ken - that perspective is hilarious! Unfortunately, I will never be able to admire the Diedrich in the same way that I used to prior to reading this.
Mark
Dogshot
Link to "Better espresso through Diedrich Home Roaster, or LM GS3?"by Marshall on Mon Sep 18, 2006 3:43 pm
When you're talking about equipment of the cost of a Diedrich (I've heard $5-8,000. Is that correct?) plus the cost of green beans, "your ability to make great espresso" would be improved most by not buying a roaster at all. Instead, you could, for less money, have dozens of the best artisan blends in the country roasted and air expressed to you every week, a pound at a time, for many years.
Buying something like a Diedrich is about other goals: having the power to experiment, the satisfaction of learning and practicing an art and the satisfaction of owning a beautifully made machine. People don't fly fish because there's no fresh trout in the market. :D
Marshall
Los Angeles
Marshall
Link to "Better espresso through Diedrich Home Roaster, or LM GS3?"by Ken Fox on Mon Sep 18, 2006 10:08 pm
Marshall wrote:Buying something like a Diedrich is about other goals: having the power to experiment, the satisfaction of learning and practicing an art and the satisfaction of owning a beautifully made machine. People don't fly fish because there's no fresh trout in the market. :D
on second thought, when can I come back over for another rendition of Joan's fish-to-die-for?
ken
:mrgreen:
What, me worry?
Ken Fox
Link to "Better espresso through Diedrich Home Roaster, or LM GS3?"by Dogshot on Tue Sep 19, 2006 10:26 pm
Marshall wrote:When you're talking about equipment of the cost of a Diedrich (I've heard $5-8,000. Is that correct?) plus the cost of green beans, "your ability to make great espresso" would be improved most by not buying a roaster at all. Instead, you could, for less money, have dozens of the best artisan blends in the country roasted and air expressed to you every week, a pound at a time, for many years.
Well, more like 4 years, by my accounting. Cost is closer to $4k, and your assumptions and costs may differ from mine, but that is even if you buy the roaster on low interest credit (6%), and pay the debt in the exact amounts and weekly rate of buying artisan coffees delivered to your door 1lb at a time. I have not factored in the cost of electricity or my own time, but I figure that the electricity would be paid for by gifting coffee rather than wine at parties. As far as my time goes, well roasting is one of my interests, and all work and no play makes Mark a dull boy (and I cannot freely substitute paid hourly work for non-paid time), so I don't place an opportunity cost on my roasting time. After those 4 years, Bob's your uncle...
Rather than take this example literally, I offer it to suggest that while no one would reasonably stop buying roasted coffees from fine roasters after buying something like a Diedrich, there is a value in the substitution of home-roasting for total dependence on the pros, and that value can significantly reduce the actual cost of enjoying the use and benefits of a nice piece of equipment. Financially, it's not that crazy an idea if you would enjoy using something with the appeal of a Lionel train set more than your current home-roast setup. (And yes, even if your i-roast dies every 1.5 years, you could replace your i-roast with a brand new one for the next 27 years of home-roasting for the same cost as a Diedrich; an SC/CO would go much further, no doubt).
Dogshot
Link to "Better espresso through Diedrich Home Roaster, or LM GS3?"by Ken Fox on Tue Sep 19, 2006 11:03 pm
Dogshot wrote:Well, more like 4 years, by my accounting. Cost is closer to $4k, and your assumptions and costs may differ from mine, but that is even if you buy the roaster on low interest credit (6%), and pay the debt in the exact amounts and weekly rate of buying artisan coffees delivered to your door 1lb at a time. I have not factored in the cost of electricity or my own time, but I figure that the electricity would be paid for by gifting coffee rather than wine at parties. As far as my time goes, well roasting is one of my interests, and all work and no play makes Mark a dull boy (and I cannot freely substitute paid hourly work for non-paid time), so I don't place an opportunity cost on my roasting time. After those 4 years, Bob's your uncle...
Lionel train set comments aside, I'd not try to dissuade you from home roasting. I probably like it less than many here, but even so I'd probably not want to stop doing it. Home roasting does give you a sense of control over the process, and there are many choices out there in green beans that you simply do not have as a purchaser of already roasted beans. And honestly, if you get into home roasting you are not going to be a regular customer of any artisan roaster; you are going to end up doing 98% of the roasting of coffees that you consume.
Don't try to rationalize the expenditure on equipment for home roasting in an economic sense, it is a total waste of your time. If you decide to home roast and you do it long enough there will be a point where you will have actually broken even over the cost of buying, say, Intelligentsia Black Cat and having it shipped to you weekly. Of course, you could have bought that "SF Bay" coffee from Costco, and if you had bought that you'll be paying more for your green then you would have paid for the already roasted stuff there. So again, trying to rationalize the expenditures of a hobby or an interest are basically a fool's errand.
With some effort on your part you can find better quality professional or semi-professional small batch roasting equipment, that is more cost effective than those Lionel train roasters. I don't know what the current under the radar offerings are as they have changed, no doubt, from when I was looking. Had I done a little bit more research I would have realized that my choice, a knockoff Probat/Jebez/Burns single barrel 1lb sample roaster from Roasters' Exchange was not terribly cost effective due to the smoke it put out and the need for better ventilation, coupled with living in a cold climate where roasting in an enclosed space was essentially mandatory. But these considerations may not apply to you.
At the very least, get a somewhat higher capacity roaster than these Lionel ones, like a 1 kg or 2lb model, and make judicious use of your freezer. Even if you have to buy another 7 cubic foot chest freezer from Costco for $215 bucks, that will still be worth it in the greater scheme of things to rationalize a slightly bigger real commercial roaster, if that is what you seek. I don't know who has what these days but a little research on your part will certainly pay off.
ken
What, me worry?
Ken Fox
Return to Home Roasting
