augustusflavius wrote:AndyS-
Can you give some more input on the use of the AST4100. I have a Fuji PXR4 and want to understand how best to use it with a AST4100 since the setting value would not be temperature related. Have you used a pressure sensor to PID an espresso machine?
You would need a PXR4 that accepts a 4-20ma input, NOT a thermocouple input. If you already own the PXR4, then it's probably too late.
You'd need a 24 vdc power supply in series with the sensor and the PID's input stage.
You'd need to provide a little passive temperature protection for the sensor, probably by simply piping it through a small coil of soft copper tubing.
You would program the PXR4 to read bar rather than degrees, although you could really do it either way.
The main advantage of all this would be a little bit faster reaction time. When you opened the steam valve, your control would instantly react to the lowered pressure. Another advantage is that it would just be more INTERESTING than another ho hum PID installation.
