Best step by step guide to Silvia use?
Link to "Best step by step guide to Silvia use?"by jonbauer on Tue Dec 12, 2006 9:41 pm
I'm new, and want to learn with no "bad habits..."
Do you guys/gals have a guide that you can refer me to that goes over the entire espresso creation process STEP BY STEP that I can follow? Would be cool if it was showing it with a Silvia, but not absolutely necessary...
- Thanx!
- Jon
jonbauer
Link to "Best step by step guide to Silvia use?"by miKe mcKoffee on Tue Dec 12, 2006 9:58 pm
aka Mike McGinness
http://www.mcKonaKoffee.com
miKe mcKoffee
Link to "Best step by step guide to Silvia use?"by HB on Tue Dec 12, 2006 10:20 pm
Silvia really isn't that complicated and the basic techniques you need apply to all espresso machines. Here's my must-read list:
For HX espresso machine owners, add:
These and other noteworthy articles on the web are listed on the Resources page. This forum's FAQs and Favorites rounds out my recommended reading. I realize these how-tos aren't specifically addressing Silvia usage, but they build the foundation of knowledge that will carry you well beyond the early learning stage.
Link to "Best step by step guide to Silvia use?"by erics on Wed Dec 13, 2006 12:56 am
Here is a Silvia specific site (almost from soup to nuts) BUT I would go with Dan's recommended reading FIRST.
Eric S.
erics
Link to "Best step by step guide to Silvia use?"by miKe mcKoffee on Wed Dec 13, 2006 1:30 am
erics wrote:Here is a Silvia specific site (almost from soup to nuts) BUT I would go with Dan's recommended reading FIRST.
Eric S.
Just be aware mentioned surf timings are based on the old 110c tstat not the newer 100c tstat.
aka Mike McGinness
miKe mcKoffee
Link to "Best step by step guide to Silvia use?"by 2xlp on Wed Dec 13, 2006 1:23 pm
2xlp
Link to "Best step by step guide to Silvia use?"by Everman on Mon Dec 18, 2006 10:18 pm
Outside of temp surfing I'd say technique is the key factor, this includes mechanics like proper dose amounts. The proper amount of coffee will yield a firm puck with a slight screw indentation after the shot it pulled, this is about 17 grams.
Make sure you keep the machine clean, water backflush at the end of a session is good, chemical backflush once a week.
Everman
Link to "Best step by step guide to Silvia use?"by jonbauer on Mon Dec 18, 2006 10:25 pm
Everman wrote:Outside of temp surfing I'd say technique is the key factor, this includes mechanics like proper dose amounts. The proper amount of coffee will yield a firm puck with a slight screw indentation after the shot it pulled, this is about 17 grams.
Rancilio says that you should never backflush the Silvia... They say that it can be damaged...
- Jon
jonbauer
Link to "Best step by step guide to Silvia use?"by HB on Mon Dec 18, 2006 10:32 pm
That recommendation has always mystified me. Backflushing is less strain on Miss Silvia than pulling a ristretto.
Link to "Best step by step guide to Silvia use?"by jesawdy on Mon Dec 18, 2006 10:44 pm
I portafilter wiggle and backflush Silvia with water only after every session. I find myself only using a backflush detergent (JoeGlo), about every 3-4 weeks. Of course it depends on volume... I do wash the basket daily and the portfilter when I detect a smell. Everything gets a detergent soak when I do a chemical backflush.
Jeff Sawdy
jesawdy
Link to "Best step by step guide to Silvia use?"by tmaynard on Sun Dec 31, 2006 8:50 pm
jonbauer wrote:a guide that you can refer me to that goes over the entire espresso creation process STEP BY STEP that I can follow? Would be cool if it was showing it with a Silvia, but not absolutely necessary...
This is a pretty late response to your question, but Whole Latte Love has quite a few videos demonstrating the use and maintenance of the Silvia.
They also sell "Getting To Know ..." CD-ROMS for various machines (I bought one of theirs for my Gaggia) -- I didn't find it within my search tolerance, but if you call them I'm sure they'll tell you if one is available. Plug the disc into your PC (not Linux, alas), and you'll find everything you'll need to know, start to finish.
Good luck!
t++
tmaynard
www.eccocaffe.com: custom coffee roasted in Northern Italian style
Return to Tips and Techniques
