jesawdy wrote:The Rocky doserless is not a bad grinder... but I would plan on committing myself to using the
WDT for consistent results. I have not used the Rocky doser model to speak to the quality of the doser, but as Dan points out, it can break up the clumps.
I have the Rocky Doser model (the original, non-stainless model) that I bought new and have been using daily for 6½ years. Although a doserless model would appear to be a good choice for espresso, there are features that make the doser desirable.
- The "TTT"
*1 method of dispensing the coffee gives better distribution and less clumping. The sound is always a part of any barista competition if that means anything.
- A doser makes it possible to grind nearly ½ pound of coffee at a time without watching a bag or container as the coffee drops as you would with a doserless model (some exceptions do exist such as the Macaps with the bag clip).
- When making multiple drinks in a row, the PF can be leveled off back into the doser to save coffee (once the grind is verified).
- The grind can be started, and if the barista is distracted, the coffee will not overflow the PF
Problems that a doser presents:
- it adds one more clean-up chore at the end of a session. But if cleanliness were a priority I would be using the Keurig exclusively..
I am looking for a replacement for Rocky- specifically to get one with infinite adjustment. The Rocky, like nearly all grinders in that price range, have a fairly wide adjustment when it comes to espresso, with one click being from three to seven seconds of pull time. it may not be a problem as you start out, but later down the line you will find it restrictive when fine-tuning your espresso.
*1 TTT - v. abbv. for Thwack, thwack, thwack. A method of dispensing finely-ground coffee into a portafilter for espresso use that nearly eliminates clumping by which the user repeatedly and quickly operates the dosing lever during the grinding process to dispense smaller amounts of coffee per dispensing cycle than would normally be dispensed.
©2007 EspressoMyEspresso.com
Also see:
