by ladalet on Mon Jul 31, 2006 1:18 am
Eric, WOW, you have owned your Cremina a very long time--1986. It is great that you still have it and are enjoying it after all this time. I really love mine. My machine is a 1983 an I have owned it just over 1 year. So, I am not really sure I should be answering your questions but instead I should be asking you questions. However, since you asked, and since to be of service is in my nature, I will do my best. Please excuse anything that is too basic. As a matter of good diagnostic procedure I find that sometimes it is good to be begin with and eliminate the basics in order to rule out the simple causes before moving on to the exotic.
Mo is correct is suggesting pre-infusion. I have dramatically improved my shots with experimenting with different pre-infusion techniques (specifically and modification of the so-called Fellini pull). With a looser grind pre-infusion could allow the coffee puck to swell and increase resistance to slow down the pour and produce a better shot.
Some other thoughts would concern the freshness of the coffee and the spacing of the settings on your grinder. I have found that in order to get a really good ristretto you need fresh coffee. Often when you purchase coffee from a store that is in a vacuum sealed bag it is often up to several months old, or when you purchase it out of a bulk bin it can be several weeks old if your lucky. To play it safe, unless the roast date is on the bin, I do not purchase from bins. If sealed in a bag and the roast date is known, I try to make sure that it was packaged and sealed no more than 10 days earlier and I used it up in less than 2 weeks from the roast date. I roast my own coffee to avoid all of this and because I have full control over roast and flavor. Others may have tighter or looser ideas about packaged coffees and roast dates. This is just what works for me.
What grinder are you using. Sometimes the spacing steps on grinders are pretty wide. When I was using a Gaggia MDF grinder I would frequently find that I needed to be in-between two settings. One setting would be too coarse and the next to fine. I would just either go coarse and tamp harder or grind fine and tamp lighter to compensate. I usually had better luck going coarse and tamping harder. I believe that the Rancilio Rocky and the Solis Maestro have wide spacings as well. The Solis Maestro Plus, Mazzer Mini, Pasqini Moka, Anfim Best and Haus, or any grinder reviewed and recommended here at HB have very fine spacings where this is not an issue.
Typically you achieve a ristretto shot by grinding a little finer and pulling a lower volume of fluid (~3/4oz instead of ~1oz) over the same amount of time (+ or - 25 seconds). I don't think that this strictly applies to levers though. My shots usually take between 25 and 30 seconds (+ or -) including a 10 second pre-infusion. I usually do not pay too much attention to time while pulling a shot. I pay attention to the mouse tails pouring out of the portafilter and adjust pressure as needed to keep the pour looking good. I end the pull usually at 3/4 oz and sometimes at 1/2 oz depending on out the shot looks at that point. I look at my timer when finished to see if I need to adjust my grind to get the time in specs. Even if the time is not quite right the shot usually is great. Once I adjust the grind to speed up or slow down the pull and get it is specs, the shot is usually sublime. However, the only right answer as to time and volume is how the coffee expresses in the cup. This are just guidelines to get you in the ball park.
I would not feel too bad if it takes a trip Espresso Vivace for you to get a better shot than yours. To be close to them is an accomplishment. They are using $1500 - $2000 grinders, and espresso machines that can run over $10,000, and professional baristas that pull shots 8 hours a day, and are quite finicky about the coffee they roast in-house and serve. There is a local roaster--Cafe Doma--that serves their own Vito's Blend using an espresso machine that is a work of art--Mirage Duette--, triple baskets, and top of the line Mazzer grinders. I just cannot manage to match their coffee either. I do however generate a little more sweetness than they do.
Best wishes,
Lance
Lance Goffinet
LMWDP #019
