lparsons21 wrote:Depending on which bean, of course, but I usually get the 1st snap of 1st crack at about 12 minutes into the roast, sometimes as much as 13 minutes.
The settings do mean something besides the initial start time. When you hit 'start' the profile is set to the time that is on the counter at the start. If you add time after the 'start' is hit, then it adds time to the end of the roast, IOW after the heat cycles that the selected profile does, or at least that was the way it was explained to me.
I am quite familiar with how the profiles and times work. The complete time is not critical since you know the final phase is what is being lengthened. The start time is sufficient to determine where the transitions will be.
Anyway, here is what I'm going to do. I'm going to select P4 as the ramped profile choice since Tom at SM's tends to like that better than P3 or P5. I'm going to set the initial time to 10 minutes. This will give the ramp during the drying phase for 6 minutes, and then drive into first crack.
This is not terribly different from what I used to do on my popper where I would ramp heat hard for 2 minutes, trim back up to 6 minutes, raise heat to drive into first crack, cut back to stretch between 1c and 2c, and then drive to finish. I do not know the bean absorption rates in this roaster to know if the P4 ramp would be helpful during drying phase, but I do know the P2 heat decrease phase is helpful for many beans. Just more reason why it would be superb to have manual control over the heat levels.
At this point there isn't enough time to roast and taste at CCC this week, so I'll try to do the three roasts next week.
