I did a P1 roast last night and charted two temperatures this time.
Obviously, neither T1 nor T2 represent the bean temperature. Since T1 would never have reached 1C and T2 would have smoked the beans.
1st crack started with slightly more than 5 minutes remaining (i.e., 15 minutes into the roast) and then I manually hit the COOL with 1:10 remaining (for a total roast time of 18:50).
T1 - The thermocouple was located below the drum and slightly behind it so that the drum and beans were sheltering the thermocouple.
T2 - The thermocouple was located in the back of the machine centerline, about 1" above and in front of the top heating element.
A couple of points of note:
1. T2 @ t = 14:30 - Large temp increase. I'm not sure what causes this or if it's a problem with the data. However, I seem to remember the voltage dropping. Another run will confirm one or the other.
2. T1/T2 @ t = 12:30 - The fan comes on and you see T1 rapidly increase and T2 drop.
3. T1/T2 @ t = 8+ These fluctuations are caused by the heaters cycling on and off. Obviously, this is more noticeable on T2 because it's located directly in front of the heaters.
4. T1/T2 @ t = 10:30 (during cooldown) - I opened the door with 10:30 remaining in the cooldown. You can see the drop in temperature, and then around 9:20 I closed the door and you see the temp increase.
I used K type thermocouples. And I believe the readings are reasonably accurate. I removed some bad data points (about a dozen, the temp was logging ever 2 seconds so there were a lot of points).
To Mike's point earlier, manual control of the heater and the fan would allow much more control of the temperatures in the roaster. However, I don't know how the heater elements would fair under the increased temperatures (i.e., what is the purpose of cycling the heaters in the later part of the roast?).
