Columbia Tests Two & Three
How slow will 1# roast with low 110v no load, P1 18min, 68 ambient, pre-heat 160/cool 10 sec.
18 - 133 (voltage load 106v)
17:30 - 135
17 - 140
16:30 - 158
16 - 158
15:30 - 169
15 - 179
14:30 - 190
14 - 200
13:30 - 210
13 - 221
12:30 - 230
12 - 240
11:30 - 248
11 - 257
10:30 - 264 fan/afterburner kick on, now 104v
10 - 261
9:30 - 262
9 - 269
8:30 - 273
8 - 277
7:30 - 279
7 - 282
6:30 - 284
6 - 287
5:30 - 289
5 - 291
4:30 - 294
4 - 296
3:30 - 298
3 - 301
2:30 - 303
2 - 306
1:30 - 308
1 - 310
0:30 - 313 add 2:30 (20:30 max for P1)
0/2:30 - 316 early 1st right after 0:30, becoming slow steady
2 - 318
1:30 - 320
1 - 322 still slow 1st
0:30 - 323
0 - 325 mandatory end of roast cool - Heater never turned off
13 - 325 closed door cooling
12:30 - 320
12- 310
11:30 - 300 opened door
11 - 281
10:30 - 259
10 - 236
9:30 - 214
9 - 194
8:30 - 182 ...
City maybe City+ best it could do with substantially low voltage, maximum 1# batch size, hottest profile, longest time possible.
How well will reducing the batch size to compensate for low voltage actually work?
3/4# P1 18 min ambient now 70 same 110v no load same 160f pre-heat cool 10 sec.
18 - 126 (load 106v)
17:30 - 130
17 - 138
16:30 - 148
16 - 160
15:30 - 172
15 - 183
14:30 - 195
14 - 208
13:30 - 219
13 - 231
12:30 - 241
12 - 252
11:30 - 261
11 - 271
10:30 - 284 drawfan/afterburner now 104v
10 - 276
9:30 - 277
9 - 286
8:30 - 291
8 - 295
7:30 - 299
7 - 302
6:30 - 305
6 - 309
5:30 - 311
5 - 313
4:30 - 316
4 - 319
3:30 - 321 early 1st 3:15
3 - 325 1st picking up slowly
2:30 - 326 1st slowly constant
2 - 327 1st continues
1;30 - 329 1st slowing
1 - 331 1st ended
0:30 - early 2nd, add 2:30 (max for P1)
0/2:30 - 2nd coming on solid
2 - 376 2nd becoming rapid, ended roast, 18:30 total time, closed door cooling. Again heater never turned off.
13 - same as 2 end of roast
12:30 332 2nd continues, still fairly robust
12 - missed temp, 2nd continues slowly, opened door
11:30 300 2nd has ended
11 - 270
10:30 - 248
9:30 - 201
9 - 188 ...
Nice 18:30 Fc+ roast, med dark brown no oil and a bit surprisingly a couple divots. (Just a bit darker than yesterday's 1# good voltage P1 batch.) With 2 minutes possible roast time remaining obviously could have gone much darker. Clearly reducing batch size from 1# to 3/4# made a big difference with 110v no load voltage. 3/4# batch size enabling dark roasting while 1# only City/City+ at best. I suspect could reduce to 14oz instead of 12oz batch and still get FC+, in longer time than 12oz batch of course, but am not going to run that roast. I believe this test illustrates the voltage/batch size/roast time relationship adequately. Those suffering from bad voltage can learn to fine tune their batch sizes accordingly, or buy a variac.
So much for running all 5 profiles 1# batch good voltage first! (But hey, low voltage was specifically asked about.) Next up 1# P1 boosted heater voltage.
