I just wanted to start a thread from RK or other BBQ drum roasters. While reading the air popper and other commonly found home roasting devices, I mostly cannot relate to the profiles, roast times, etc. I really am under the impression that a huge chasm exists in the attainable flavors profiles between a fluid bed and drum roaster.
I have a little old CharBroil grill that makes maybe 35k BTUs. I drilled a hole right through the middle at about bean height and mounted a K-Type T/C on a piece of steel pipe. I also have a mechanical thermometer sitting on the tin pan I have over the burner (to diffuse the flames). I usually keep the heat around 470 - 490 F with the first snap of 1st crack coming around 10:00 and the first snaps of second coming around 15:30.
Of course, results vary.
Chris
