Cakesniffer wrote:I think I went about this the wrong way, cutting down into the bottom of the container to try to extract the bottom circle. Probably makes more sense to cut a straight line into the side of the container right at the bottom.
How far should the yogurt container go into the PF? Seems like it needn't touch the bottom, and in fact it would be better (tighter) if it didn't?
cannonfodder wrote:You could try a hacksaw blade. The fine tooth will cut relatively smooth and the length of the blade will cut more even.
IMAWriter wrote:I often incorporate the WDT when pulling triples, and when not rushed my doubles as well. A very useful technique! However, I must respectfully disagree with one of the author's statements (and I paraphrase) "by vigorous stirring, the grounds become fluffier [true], thus yielding a greater amount"..[untrue]...at least for me, it works like this, the more I stir...say 6-8 seconds, the air molecules contained within the grind are somewhat dissipated, thus leaving me with LESS volume in the basket...by size (that is...volume), obviously not by weight. My 17g barely reach the top of my double basket...a little tougher to perform the Stockfleths...haha....but the proper amount is in the basket...
If I still had my Rocky doserless, I would never dose/distribute any other way than with the WDT....Bravo!
RapidCoffee wrote:Hi Rob, and thanks for the kind words. You're right, it would be more accurate to state that the WDT allows you to modify the dose. Stirring could certainly lead to updosing by removing air pockets in the puck. To downdose, try removing the yogurt cup, leveling, then stirring and leveling again without the cup. (But to hit a specific dose, weigh the grounds.)
BTW, I lived in Nashville (all four syllables: Na-yash vi-yal)) for almost a decade (1975-84). Nice town!
carlx wrote:For even better distribution, try sifting the coffee in a small, course sifter. Works better than a needle.
TimEggers wrote:John,
Again I must thank you so much for sharing this practical approach. It has been the single best advantage I have had learning home espresso. It's amazing that the WDT and a bottomless portafilter have in such a short time given me truly amazing espresso at home.
My shots bead so evenly and espresso is truly beautiful. I owe my progress to the WDT, it remains the single most important tool for the budding home barista to quickly and effectively establish a consistant technique.
I owe my greatest shots to the WDT.
(now if my espresso wasn't so darn good I wouldn't drink so much of it!)
Thanks John!
TimEggers wrote:I used to think that a "real" barista doesn't need the WDT, in truth the real barista strives for the finest espresso quality. For me that's WDT. Well done John, I guess I'm a reconvert!
RapidCoffee wrote:Many thanks for the kind words, and I'm always glad to hear it's helping someone. I would never claim that anyone "needs" to use the WDT, but I believe it does improve my pours by (in Tim "cajun_brew" Brunson's words) eliminating one of the variables: in this case, distribution errors.
Canuck wrote:Has anyone found something other than a yoghurt cup, that fits standard 58mm baskets? I was thinking that if the item was metal, or of another material that reduces static, it might help? Though I guess if you stir up the grounds afterwards you're removing clumps anyway...
shadowfax wrote:I would still like to find an alternate to the yogurt cup though, as it is kind of an ugly tool compared to the other things I use to prepare my coffee...
Canuck wrote:My current technique: after stirring the grounds, I remove the yog container, tap the basket down lightly on the counter, then do a n,s,e,w twice (2nd time pushing grounds off the basket).
If I thought it would work as well, I would prefer to just sweep/level the grounds with say the back of a knife (after tapping the basket lightly on the counter?), followed by a light tamp then 30# tamp. I think (many months ago) I tried this but found that after tamping, the puck didn't compress far enough into the basket and it would often touch the shower screen when I locked in the PF. I guess my n,s,e,w means less coffee in the basket...
