Astra Gourmet or the Brewtus II?
Link to "Astra Gourmet or the Brewtus II?"by ronace on Mon Mar 20, 2006 10:31 pm
OK: I'm down to two machines. The Astra Gourmet (automatic) or the Brewtus II. I must have a pour over machine. Direct connection is out of the question. I've got the 20 amp line so the Astra's 2kw is no problem. I'm familiar with all the attributes of an HX machines and its flushing rituals as well as the advantages of a temperature controlled dual boiler set up. Steaming capacity is not of primary importance as I'll probably only draw a few shots at a time. The Automatic feature of the Astra is a plus since my wife will be using the machine quite often and the simpler the better.
With all that being said, it comes down to just one question, which machine makes a better tasting espresso?
ronace
Re: Astra Gourmet or the Brewtus II?
Link to "Astra Gourmet or the Brewtus II?"by Ken Fox on Mon Mar 20, 2006 11:00 pm
ronace wrote:OK: I'm down to two machines. The Astra Gourmet (automatic) or the Brewtus II. I must have a pour over machine. Direct connection is out of the question. I've got the 20 amp line so the Astra's 2kw is no problem. I'm familiar with all the attributes of an HX machines and its flushing rituals as well as the advantages of a temperature controlled dual boiler set up. Steaming capacity is not of primary importance as I'll probably only draw a few shots at a time. The Automatic feature of the Astra is a plus since my wife will be using the machine quite often and the simpler the better.
You've got it entirely wrong; the machine does not make the better espresso, you do.
The only difference between an "automatic" and a "semi automatic" machine is that the automatic attempts to time the shot with a flowmeter, measuring volume but not shot quality. If your wife really is so uninterested in the quality of the beverage she produces that she can't even look at the shot as it pours in order to decide when to terminate it, then she "deserves" either a superautomatic or a pod machine.
I'm really not familiar with either of these machines you have chosen, but my opinion is that you have narrowed down your choice to a couple of niche machines, for reasons that don't make a lot of sense. I think there are a huge number of machines that will make espresso drinks as good or better than either of the ones you have cited, and your reasons for excluding them from consideration sound silly, at least to me.
ken
What, me worry?
Alfred E. Neuman, 1955
Ken Fox
Link to "Astra Gourmet or the Brewtus II?"by HB on Tue Mar 21, 2006 12:19 am
ronace wrote:With all that being said, it comes down to just one question, which machine makes a better tasting espresso?
I saw the Astra Gourmet at last year's SCAA and talked at length with Richard (last name?), who designs / manufacturers it. He willingly removed the covers and answered the most detailed questions I could pose. A well constructed machine, and the accounts from owners (e.g., Greg Scace, Rob Hall) are positive.
As Ken says, the espresso machine is typically not the gating factor to great espresso, especially for the class of machines we're discussing (threads like It's the Barista, Stupid are my mini-rants on the hardware obsession, of which I am frequently an active participant). However there's a lot to be said for the ease of mastering the use of an espresso machine, a measure HB's buyer's guides try to capture in the "morning after" score. The Expobar Brewtus did very well in this regard; Abe explains why in the conclusion:
Abe Carmeli wrote:The key words in the "Brewtus advantage" are: ease, consistency, and repeatability. In testing the Brewtus temperature control, I tried to answer two questions: Does it deliver the brew temperature that its digital controller displays, and can it do it repeatedly with no fuss? The answer is a confident yes. However, there is room for more refinement in the Brewtus temperature selection, since some demanding home baristas may find the 1°C increments (about 1.8°F) to be too wide for their preferred coffees.
If you are concerned about your wife learning to use the machine ("the simpler the better"), then I would suggest weighing the morning after score more heavily than other factors in your deliberations. An espresso machine with a dedicated brew boiler (Expobar Brewtus, La Spaziale S1, Quickmill Eliane / Fiorenzato Colombina... up to the La Marzocco and Synesso Cynra) has the advantage of simplified temperature management. However, whether the "double boiler" advantage remains distinctive in the hands of an experience barista is frequently debated.
Link to "Astra Gourmet or the Brewtus II?"by hperry on Tue Mar 21, 2006 12:22 am
Ken Fox wrote:You've got it entirely wrong; the machine does not make the better espresso, you do.
I've seen this statement frequently and recognize its truth. It takes a lot of hard work on the barista's part and understanding of his/her hardware to get it to produce the best espresso. However, the machine is not, in my opinion, a matter of indifference.
My son wants to "just walk up to the machine and get a shot." The Nespresso was a pretty good choice for him.
After learning to use an HX and being able to produce decent coffee with it, I'm a whole lot happier with the forgiving nature, and easy, accurate temperature control of my Termozona lever than any of the other four machines that I have used. It pulls a great cup of coffee every time and it gets to and stays at temperature with ridiculous ease. Sink shots are way down. I was pretty good with the Bezerra. But would it be my machine of choice to get consistently good results. No.
If I have an "inventor" streak, like to spend hours solving problems and learning the intricacies of a machine I might choose one machine, whereas if I just wanted to pull and go I might choose another.
I do think its true that the writer has not given us enough information about his priorities to allow a good response to the question. Knowing what he wants to accomplish with the machine, and why he has narrowed his choices down to these two would be helpful. In a vacuum, it's difficult to respond.
Hal Perry
hperry
Link to "Astra Gourmet or the Brewtus II?"by Ken Fox on Tue Mar 21, 2006 12:47 am
hperry wrote:I've seen this statement frequently and recognize its truth. It takes a lot of hard work on the barista's part and understanding of his/her hardware to get it to produce the best espresso. However, the machine is not, in my opinion, a matter of indifference.
The point is that the question posed by the OP betrays the fact that the OP doesn't know enough about what he is aiming to buy, in order to make an intelligent purchase. And, as you point out, we can't help him to do so, either.
I don't even know what constitutes a "better shot," to be honest, and I've been doing this sh*t at home for more than 10 years now. Those "better shots" for me have been a moving target. I used to think it was a drinkable cappuccino, but if I were to be confronted with what I thought was drinkable 5 years ago I'm sure it would go straight down the sink. I used to think that Lavazza was drinkable back then, or shortly before then.
Nowadays, I'm drinking mostly SO espresso, and lately have been enjoying a particular Harrar Horse. If I were to make this into my usual 1.5 oz double shot and serve it to this guy, would he like it? Who can know? But it is the result of 10 year's effort on my part, both in espresso preparation and (more recently) in home roasting. Anyone who asks people he doesn't know to tell him what is "best," in anything, does not know enough to ask the right questions. There is no "best" machine, just a number of different good machines that in the right hands can make a good end product.
Getting back to the OP: do not think that you can spend a few hours reading equipment reviews and narrow down your choices to the point where you can make an intelligent decision. If you are looking to spend a few hundred dollars on a beginner setup, then yes, you can probably do that. But that won't be what you keep over the long haul. If you are trying to decide on an expensive high end setup, there is no substitute for experience, the kind of hands on experience that only your own efforts and time can produce. Go out and buy a good grinder, and a cheaper machine, something like a Solis or a Silvia, and play around with it for 6 months. Learn what it is that really interests you when it comes to espresso production. Try some different coffees, from different producers. If you buy a good enough grinder, then you can keep it and use it on your next machine. Sell the Silvia or whatever on ebay, and get back most of what you paid for it.
Only after you go through this process will you have any idea what is worth paying attention to and what is just blather, when it comes to reading postings and reviews of espressomaking equipment.
ken
What, me worry?
Ken Fox
Link to "Astra Gourmet or the Brewtus II?"by HB on Tue Mar 21, 2006 12:57 am
Ken Fox wrote:Go out and buy a good grinder, and a cheaper machine, something like a Solis or a Silvia, and play around with it for 6 months. Learn what it is that really interests you when it comes to espresso production. Try some different coffees, from different producers. If you buy a good enough grinder, then you can keep it and use it on your next machine. Sell the Silvia or whatever on ebay, and get back most of what you paid for it.
That's not an entirely crazy idea. The guy who bought my Silvia / Rocky sold it years later for the same price. Even at full retail, buying popular upgrade "victims" will give you a good chance at recovering 60% of your purchase price, maybe more.
Link to "Astra Gourmet or the Brewtus II?"by hperry on Tue Mar 21, 2006 3:03 am
Ken -
Your post is really helpful in reminding me how much serious digging it takes to have a somewhat informed opinion about what machine makes sense taking into account an individual's taste, personality, and preparation priorities. Your earlier posts re: lower pressurestat settings, for example, helped me obtain quite good temperature stability with the Bezerra during the end of the time I used it. Going from 1.1 to .8 helped me hit the target temperature (about 200 degrees) with a lot more consistency while still retaining good steam. I achieved shots that were very satisfying to me. Interestingly, some of the best performance in temperature stability was with the cover off completely.
And some of the things you learn are quite puzzling. While I can improve the shot on the Termonzona (a commercial lever) by pulling it up to 200 degrees or so, I get very drinkable shots from 195 to 201 with Caffe Fresco Ambrosia, for example. Obviously other things than temperature in degree (maybe pressure profile and rock solid temperature stability?) are at work. Just when you think you've "got it" you are off in a new direction.
I agree that buying the best grinder you can get and a modest machine to get your bearings is a good idea. The biggest single improvement for me in coffee making was the Versalab grinder. Now, if I had $1,600 to spend, I would get it first and whatever machine I could buy for $400 (a good Conti lever sold for $455 on Sunday). But, I sure wouldn't have believed that when I first started reading posts here a year ago.
Thanks much for the contributions you have made to my enjoyment of coffee.
Hal Perry
hperry
Link to "Astra Gourmet or the Brewtus II?"by ronace on Tue Mar 21, 2006 10:55 am
Guys:
Before I start just let me say thank you to all who have responded to this post. I respect each and every opinion and do understand what you are trying to tell me.
In my haste to get my question answered I didn't bother to detail my experience or backround. My espresso days began in Italy way back in the early sixties. Although I am American I lived in Italy for about 5 years, even marrying a native born Italian gal. (I'd do it all over again if I could). My taste for espresso was nurtured in Italy, and to the point that I was able to differentiate the taste between the various regions of Italy. With the best Espresso I ever tasted coming from a small town in Southern Italy, near Bari.
My experience with coffee machines began about 20 years ago with the purchase of a SECO manual machine (Non HX) and then more recently (2002) of a Capresso Super automatic C3000. Along with the C3000 I also purchased the Rocky Rancilio Grinder. I just sold the C3000 on E-bay as a prerequisite to the purchase of a new machine. The SECO manual was a more superior machine as far as its ability to make good tasting Espresso. The C3000 was also a good machine for which it was designed. Simplicity. IMO, It did not make as good an Espresso as the SECO, not even in the same league. I sold the C3000 because I wanted to graduate to the major leagues and have a machine that could reproduce those wonderful early Italian experiences and flavors.
The purpose of my choosing these two particular machines was based upon price and the understanding of the differences between the Vibe and Rotary pump (Astra) and Temperature and dual boiler set ups (Brewtus). The Auto feature of the Astra is nice but not essential. Yes, my wife could operate a non Auto machine if she had to.
In thinking about what Ken said "I don't even know what constitutes a "better shot,"" I would say that "Beauty is in the eyes of the beholder" What ever tastes better to you constitutes the "better shot" regardless of how you got it.. What else can we go by other than taste?
So in concluding I'll rephrase and ask the question again. In the hands of an experienced Barista, using the coffee and grinder of his choice could this Barista produce a better tasting shot using one machine over the other?
Thanks for listening
Ronace
ronace
Link to "Astra Gourmet or the Brewtus II?"by hperry on Tue Mar 21, 2006 11:50 am
No - either would work given the "experienced barista" and a "grinder of his choice" if it was a Mazzer, Macap or Versalab. The experienced barista would have options that would produce glorious coffee from either. The machines that you've used probably don't provide you the requisite reference to know what you want.
Right now, with the purchase price you are proposing I'd research and buy as much grinder as I could afford and start with any espresso machine that is consistently well reviewed and is under $1,000. After a year or so playing with it you will have a reference point for your next purchase. I absolutely did not know when I bought the Bezerra BZ40 with a rotary pump and plumbed it in, that my "best" machine (right now) would be a 30 year old commercial lever. That conclusion came from considerable experience with the Bezerra (a very good machine) and wise counsel from these forums.
As I said in my previous post, knowing what I know now I would have bought the Versalab grinder first - that will probably not need to be replaced and makes more difference than any variations in machines. In its current form, there is no answer to your question.
Hal Perry
hperry
Link to "Astra Gourmet or the Brewtus II?"by ronace on Tue Mar 21, 2006 12:34 pm
hperry:
Does this mean that my Rancilio Rocky will not produce the taste I'm seeking and that a different more expensive and decidedly better grinder would? I didn't realize that grinders in the $300 plus range differed to the point that you could taste the difference.
Interesting!!
Ronace
ronace
Link to "Astra Gourmet or the Brewtus II?"by hperry on Tue Mar 21, 2006 12:57 pm
Start with the Rocky - it has a good reputation. Hone in on an under $1000 machine, knowing that it is disposable and that you will probably change both grinder and machine after you've worked your way through them.
Having said that, based on what I know now, I'd start with the Versalab because it is reference, then would get whatever I could with whatever money I had left in a well-reviewed machine. I would know that I had eliminated the "front end" variable and would develop the experience over a year to make a longer-term investment in a machine that satisfied me. I had a Macap M4 prior to the Versalab. The change to the Versalab was the most important change I've made since I started taking all of this seriously.
Hal Perry
hperry
Link to "Astra Gourmet or the Brewtus II?"by HB on Tue Mar 21, 2006 1:05 pm
hperry wrote:The change to the Versalab was the most important change I've made since I started taking all of this seriously.
Oh no, I hear the Sirens of Versalab taunting me again! Unexpectedly, in the end, the vote was firmly against upgrading. They've offered to loan us the M3 grinder for EspressoFest; I look forward to acquiring an informed opinion.
Link to "Astra Gourmet or the Brewtus II?"by Ken Fox on Tue Mar 21, 2006 3:32 pm
You obviously have more experience with this stuff than I gave you credit for. Sorry.
Let's take these things separately; for the grinder, you could certainly keep what you have for now; lots of people who make good shots swear by the Rocky. I have never owned one, although I have played around with a couple that friends have owned. The positive about the Rocky is that you already own it, and with some effort you can get excellent shots out of it. The negative is that the build quality, especially of the doser, isn't too great, and the burrs are small and wear out relatively quickly from what I have seen posted. In addition, the adjustability is not at the same level as a true commercial grinder or even one of the cheaper but less well constructed connicals, like the Innova, Lux, and Vanelli. Speaking for myself, I would not consider a Versalab, especially if it was going to be used for anything other than cupping or someone who wants to constantly change the coffee they are drinking. Jim Schulman finds it useful for cupping but I think he would find it unpleasant to use as an everyday grinder. I know of at least one other alt.coffee type owner who rarely uses his at all. Your wife would undoubtedly hate it. If you want a connical, the buzz is that Cimbali is coming out with a new one that will cost around $750. To my knowledge it is not yet available in N. America. I have a couple of Cimbali Jr. grinders that I'm happy with, but then I'm not constantly changing blends and beans. Jim Schulman, who recently visited me, found these Cimbalis inconvenient for changing coffees as often as he would like to.
For the espresso machine, there are scads of machines out there. Important things to know are how high is your budget, whether you are handy, how much room you have for this stuff, and whether you are a fan of bulletproof high end machinery. If you like big well constructed machines, you might want to consider a full on commercial machine; these can often be obtained in the secondhand market for less than the semi-commercial grade equipment you are looking at. If you like to work with you hands and have basic electrical and plumbing skills, you could pick up a used one group commercial machine and restore it yourself. This is something that many home users have done and in the end you will end up with a very high quality piece of equipment, assuming you can fix it up. The same applies to used commercial grinders; often, these need only a new set of burrs and you will have essentially a new, high end grinder, other than for any cosmetic defects that may be present. It is obvious, however, that when buying used commercial equipment you know what state it is in when you buy it and that you have the skills to fix it up. Sometimes dealers get such pieces of equipment in trade and restore it themselves, then selling the stuff as used but restored at a significant discount compared to new stuff. I am a fan of Cimbali equipment, especially the older style vibe pump operated stuff that dates back several years, before they overloaded the machines with electronics and autofill. This one, now ten years old and significantly modified, sits in my kitchen and you'd have to pry it out of my cold dead hands :P
Unless you live in a major metropolitan area with a good dealer nearby, you are probably going to end up having to work on the machines eventually, yourself, anyway, so a restoration job, if you are up to it, might be a good and moneysaving option.
I personally would not limit myself to the machines you are considering. The best bang for the buck in a new machine is probably going to be a higher quality e-61 HX machine. There are scads of them out there, the parts are readily available with few proprietary so repairs will be cheaper, and they are fairly easy to work on from what I have read. The Brewtus in its stock configuration is probably not going to be any more temperature stable than would an E-61, especially if you make more than one shot at a time.
Good luck,
ken
What, me worry?
Ken Fox
Link to "Astra Gourmet or the Brewtus II?"by k7qz on Tue Mar 21, 2006 3:45 pm
Ken Fox wrote:Nowadays, I'm drinking mostly SO espresso, and lately have been enjoying a particular Harrar Horse.
Sorry about the brief "hijack" here guys, but I'll ask my question and get out of the way-
Ken: I'm always looking to try another home roasted SO. Which Harrar are you pouring here? Thanks!
k7qz
Link to "Astra Gourmet or the Brewtus II?"by Ken Fox on Tue Mar 21, 2006 3:51 pm
k7qz wrote:Sorry about the brief "hijack" here guys, but I'll ask my question and get out of the way-
It is this one, which is no longer available as it is last year's crop. Chuck at coffeewholesalers.com has a new one but I've not tried it yet.
http://www.coffeecuppers.com/Reviews/js0002.htm
I'm roasting it in a 1lb Probat/Jebez/Burns knockoff sample roaster, about 30 seconds into rolling second crack and ending the roast in a total roast time of 12-13.5 minutes, never exceeding 14minutes.
ken
What, me worry?
Ken Fox
Link to "Astra Gourmet or the Brewtus II?"by onemoreshot on Tue Mar 21, 2006 4:51 pm
Ronace,
You got some good responses, good advice. I can appreciate how difficult it can be to make the decision you are looking at as I went through a variation of it myself. As discussed, "better espresso" may not require "exotic" hardware. I am using a Brewtus II, Macap, home roasting, etc and find I get some very good results. Why a Brewtus II - well having pulled thousands of shots on my commercial three group HX machine in my cafe' setting I wanted to have something at home which by all reports demonstrated precision at the E-61 grouphead via a digital input. Not that the Brewtus II is necessarily the be all end all in this price range, it just happened to suit my needs. There are other reasons but they may not be applicable to your situation. The Macap - it was the smallest grinder I had in my cafe' and it found its way into my kitchen.
The most important things I have learned in the last year which have gained me the biggest leaps in improvement are things like:
- Technique
- Precision
- Experimentation
- Constant learning
- A critical eye to my own efforts
Forums such as this have been immensely helpful (thx Dan) as have a lot of unnamed coffee personalities.
I know this won't help you make your decision, ultimately it will be your call, but you are doing the right things; asking questions and keeping an open mind. If you have any questions for me specifically I will gladly try and answer them in this thread.
onemoreshot
Return to Espresso Machines
