I have bought a one group Astoria commercial semi automatic.
This is the photo that was used to advertise it. It was sold as a running machine
and I tested it to see it worked more or less before buying it.
I was quite interested in taking the machine apart,
I never intended to really use the clearly very dirty machine without a renewal.
My main source of inspiration to do this have been these reports,
Where nearly identical machines are taken apart and put back together.
http://www.home-barista.com/forums/laurentis-rejuvination-project-moved-from-alt-coffee-t1413.html#11814
As well as
http://www.home-barista.com/forums/rebuilding-single-group-astoria-lever-t1416.html
Opening up the machine there is hardly any outside scale.
I think that the machine has been taken apart/ serviced before as not all
screws that are to hold the body panels in place are present.
I have no idea when it was built, though the brown colour would suggest some time
in the 80s, any ideas on this anyone?
what I noticed is that both the water inlet and brew group solenoid are not grounded.
is this normal, or should I ground it when building it back up.
I have ordered some components from coffee XXL today,
mostly O rings, a new vacuum breaker, and a bottomless pf.
So far I have taken and put back together the boiler fill system.
No real surprises here, except the sight glass, in which the indicating ball
is held suspended in mid air by a layer of scale in the glass.
At the moment I am taking apart the brew system.
The dispersion plate just above the shower screen shows that
this is a good idea: of the eight holes in this plate,
all but two are blocked up by crud.
I have damaged the nut holding the brew group solenoid coil in place.
once i have taken more parts off I will try to get it off again.
My plan for the machine is to:
- replace most rubbers, seals and gaskets taking apart a bit of the machine at a time.
- Get it cleaned- it is very very dirty
- get it working again and replace the wires where necessary
- repaint the brown body panels, maybe with a dark red colour
- insulate the boiler as the machine will be used in a domestic setting.
Optional and vague plans
- do something with preinfusion, a separate switch, or a delay mechanism
- resurface the stainless body panels.
- make a timer
- change the Americano wand to a shorter one.
Any suggestions are welcome.
