Descaling Victory!
Muriatic Acid or dilute Hcl was the answer for me. All discussions aside about safety, respirators, baking soda treatments, inhalation dangers, environmental hazards and melting body or espresso machine parts - it did what I needed or wanted it to do - remove the black scale. All of it. And without injury to me, the machine or the shoes I spilled it on for a day. Again as the new guy, I have no idea whether or not some scale is bad so I'm working on this thing like I work on car engines - cleaner is generally better.
After about 6 hours in the acid bath (14% concentration cut 1 part acid/2 parts H2O) the parts were clean. I would dunk them in and leave them for 30 minutes, come outside, don gloves and scrub with steel wool for a couple minutes and re-dunk it. There were some particularly meaty chunks of scale on the back side where the bolts go into the boiler that I chipped at with a screwdriver.
I rinsed everything on the lawn and dunked it in a bucket of water after achieving cleanliness. Then it went in the dishwasher when the wife went to the health food store. All of the brass and boiler fit in. I put it on the max length cycle with plenty of detergent. Since I had used WD-40 to disassemble some of the parts, two acids to descale them and been working on parts of it on the floor of my basement - it seemed like a reasonable step. I set it for a long rinse and it all came out looking pretty good. Even the coffee oil/grind paste came off of everything.
Here's the bucket on the lawn. It's a kitty litter one and it fits the 7L boiler perfectly. You can tell when the acid is getting used up when you can't see to the bottom. Next time, my roommate will provide a ph meter and I'll have some notes on how used up it was. It definitely gets slower as you go. I used all 2 gallons of it.
This was second to last out of the acid. There were deposits on the top of the bumps that disobeyed for a while but the acid won.
This is my magnum opus thus far. Spotless although a little less bright after 2 hours in the dishwasher. It's kinda dented where some of the fittings are brazed on but I imagine that it doesn't affect performance.
This part took some scrubbing to remove a paper gasket material. Anyone know what the two holes on the bottom are for? Pre-heating the grouphead with HX water bubbling through?
This one is spotless. Inside and out.
Here are some of the other bits after various combinations of acid soaking and washing.
NEXT
- Frame and panels are in the car as I shop around for a decent blasting/powder coating deal. I'm in Seattle and just for the frame I was quoted $150 for black powder. That was higher than I was hoping so I'm shopping around, I'll let you know what I find out. Not sure what color to do the panels in but it will figure into the cost as well.
- A member of this board near me has graciously offered to help me puzzle through small parts and a new pressurestat.
- I wired a 220v outlet above the workbench for diagnostic purposes and will also dig into the wiring harness this week.
WES
