by rfc on Sun Sep 18, 2005 9:00 am
I started with Sulawesi from Sweet Marias, roasted 4 days prior to grinding and pulling. Still not exactly prodigious amounts of crema, but at least there was a light brown film on top of the 'spresso, which to this point I had not seen.
I spent all day Saturday looking for a stupid West Bend Poppery I at yard sales, flea markets, to no avail. I was not going to be discouraged by this setback, so spent $9 at my local hardware store on some stovepipe, hardware cloth etc. and put together a respectable Barbeque Rotissery Roaster (Photos provided on request).
Fired it up, burned off whatever might have been on it, and first tried the same Sulawesi and nearly created a new roast level past Vienna--How do you say "Charcoal". I had all three burners and the infrared burner on high; unit was at 525 (inside the cover), but Whoa! Talk about Roast Coast!
After the local Fire Department was alerted to Stand Down, I tried again and got the Sulawesi into the colander at about 15 seconds before second crack.
Proceded to do the same with Sweet Maria's Monkey Blend, and also their Puro Scuro (or whatever it's called). Mopped up and waited 12 hours.
Of the three, The Puro finally gave me about a 1/4" of nicely colored crema on about a 1/3 of a cup double. First drops in 8 seconds, 26-30 seconds to blonding. Success?
Maybe not so fast.
During this little escapade I learned that the sheer number of variables doing this: The machine, the flush, the type of coffee, the roast, the grind, the tamp, the pull.....I am surprised I got anything drinkable at all.
I feel like a single engine pilot (which I am) reading the Boeing 747 chapter in "How Things Work", then getting in and expecting I could get the thing off the ground by randomly switching every lever in sight.
I'm still using a crappy Braun "propeller" grinder so I know I can't expect much, but now that I know that if I get enough of the variables close, I can get this to work.
My strategy will change, however. I am going to focus on a SINGLE blend--maybe the Monkey, buy some preroasted by Sweet Marias, use that as a baseline for my own roasting, then pull and pull and pull changing only one variable at a time until the crema gets plentiferous, the bitterness goes away, the pucks pop out dry, and I'm perpetually buzzed on caffeine.
