Any tips on how to modify Elektra A3 for no drain?
Link to "Any tips on how to modify Elektra A3 for no drain?"by rudedude on Fri Feb 10, 2006 4:50 pm
I'm interested in the Elektra A3 machine for my home, but concerned that plumbing to my drain will not be possible. I have talked to several companies that sell them and they have not been able to come up with a suggestion for a work around. Chris Coffee suggest I post here and perhaps someone has a lead or a tip for how this machine can be modified to drip tray not connected to drain?
Any thoughts, advice or leads is appreciated!
Paul
rudedude
Link to "Any tips on how to modify Elektra A3 for no drain?"by HB on Fri Feb 10, 2006 5:57 pm
That's definitely a problem since the driptray is very shallow and the controller is directly beneath it. Assuming that you have room under the cabinet, you could add a wastewater collector. A two gallon jug would take a long time to fill up.
www.vanelis.com: top-notch espresso equipment and customer support
Re: Any tips on how to modify Elektra A3 for no drain?
Link to "Any tips on how to modify Elektra A3 for no drain?"by espressoperson on Fri Feb 10, 2006 6:21 pm
rudedude wrote:I'm interested in the Elektra A3 machine for my home, but concerned that plumbing to my drain will not be possible. I have talked to several companies that sell them and they have not been able to come up with a suggestion for a work around. Chris Coffee suggest I post here and perhaps someone has a lead or a tip for how this machine can be modified to drip tray not connected to drain?
Paul
I use a low tech method. A glass one cup pyrex measuring cup fits perfectly under my grouphead and steam wand. I just move it under when flushing, bleeding the steam wand, or to catch the blonding stream when I pull the cup away. I've been doing it this way for years and almost never have to empty or clean the drip tray.
MichaelB, LMWDP #24
espressoperson
Link to "Any tips on how to modify Elektra A3 for no drain?"by k7qz on Fri Feb 10, 2006 6:27 pm
HB wrote:That's definitely a problem since the driptray is very shallow and the controller is directly beneath it. Assuming that you have room under the cabinet, you could add a wastewater collector. A two gallon jug would take a long time to fill up.
Yep, mine drains into a 5 gallon water dispenser bottle (purchased at Walmart for about $5) located under the counter. About once a week I take it out and give my garden a nice drink of espresso water. It's supposed to be good for plants! (Dan is right, the drip tray is too shallow to plug the drain hole and use it as a "manual drain" tray-you'd be dumping it every few shots).
In order to drain my A3 in dedicated fashion I would have had to drill through my wife's Italian Marble kitchen counter tops- Not good for marital harmony... :lol:
IMO, this machine is too great to let a little thing like this slow you down! :D
k7qz
Return to Espresso Machines
