Teme wrote:If I do not find something locally, I do shop around online. Usually ordering from the US is not a viable option.
I figured that was the case. There was a thread about Giotto Premium owners looking for an adapter on CG and they mentioned the same piece from the water tap you noted. However, I wasn't able to find the thread again.
In cases like this, I start with the vendor. They can special order parts and I've done so before (both from Chris' Coffee and 1st-line). You have to be patient though, and have a vendor who's willing to go through the effort of finding the part number and placing the order. Some will charge a premium for special orders. If that doesn't work out, I would either (a) order a stock steam arm and forgo the "no burn" one, or (b) talk to a machine shop. Fashioning an adapter with compatible threads would be easy, although again it may be expensive simply because it's a special order.
BobY wrote:I was getting better foam on my Silvia with an aftermarket 3-hole tip.
Chris' report on the Mia got me thinking about these so-called "cheater tips" and how they simplify texturing. But do they stretch well too? The A3 is a steaming monster, but once you get the hang of the speed with which it stretches and textures, the result seems sweeter. I would like to schedule some side-by-side comparisons though to confirm this assertion.
