Dogshot wrote:Thanks for all the advice. I think I'll start with a mask, and change the way I handle the green coffee. I use an i-roast and roast outside, and have already modified the way I interact with the roaster. I noticed the symptoms originally while roasting, and I think it is because the i-roast vents directly upward. Now I start the machine like I'm lighting fireworks - light the fuse and run. I come back just as 1st crack is underway, and have no problems from that point on. Hopefully it will never come to needing medication. If it does come to that, I'll just outsource the entire activity.
I would have thought that a runny nose and sneezing would be more common among home-roasters when handling green coffee, given the stats on others who regularly handle it. It's also probably a good idea to keep green coffee away from asthmatics and young children.
Mark
I've had a similar experience with Jalapeno peppers when we sautee them in a skillet- I sneeze, and cough, etc... Coffee roasting has no effect on me, but I don't react to pollens in Arizona anymore (there was a time about 9 yrs ago when I did, though-- guess I've finally burned out those memory cells-- other people aren't so lucky). I've worked in an ambulatory/endocrine clinic seeing patients for several years, and I think we have one of the longest pollen seasons around producing some of the most challenging cases of allergic rhinitis (approximately 9 months long, counting all varieties)- by far, the most effective antihistamine (if you are objectively looking at symptomatic relief) is diphenhydramine. In general, the less powerful the antihistamine, the less effective, too. Here's the order of potency: diphenhydramine > chlorpheniramine/brompheniramine > triprolidine/clemastine > loratidine. medstudent is right, loratidine is way less sedating, but at the cost of effectiveness. I agree- avoiding exposure to anything foreign is the best solution, just sometimes not avoidable. Anyway, if the mask solution doesn't work (I actually like your "hit the button and run" option best), then post the problem again. I have to admit- most of my patients have no options available; so using antihistamines or steroid inhalers are a must. Incidentally, Claritin (R) is a brand of loratidine- not the other way around.
PS. Thinking on this some more.. I wonder if building a ventilation hood of some sort might help? In any event, if hitting the button and running is working, sounds like it's a moot point (and you get exercise in the process!)
Ray
