www.vanelis.com: top-notch espresso equipment and customer support
Advice on grouphead gasket removal needed
Link to "Advice on grouphead gasket removal needed"by poniday on Sat May 24, 2008 2:12 pm
Any advice on how to pry off a 2 year old (o-ring) seal without taking off your finger(s) or losing an eye? I have a la Pavoni Bar V2 and the seals have never been changed. One of the portafilters is leaking (surprise) and I cannot get the old dried up cracked seal off.
http://www.poniday.com
Shirley K's Coffee Shop
poniday
Link to "Advice on grouphead gasket removal needed"by mhoy on Sat May 24, 2008 2:45 pm
I know nothing about your particular machine.
Some people have resorted to sinking screws into the hardened rubber and pulling on the screws. (Including a friend of mine). If you go this route, don't sink the screw into your group head, but I guess you know that.
Just reading about some of the problems people have has led me to purchase and replace the seal on my Anita. Of course it cracked in half when I eventually got it out.
Mark
mhoy
Link to "Advice on grouphead gasket removal needed"by Marshall on Sat May 24, 2008 3:23 pm
This works very well.
Marshall
Los Angeles
Marshall
Link to "Advice on grouphead gasket removal needed"by mhoy on Sat May 24, 2008 3:59 pm
Another thing, don't turn it on it's side or upside down (unless you drain the water first) since it will leak and get water in places you don't want to have wet.
Mark
mhoy
Link to "Advice on grouphead gasket removal needed"by Psyd on Sat May 24, 2008 5:33 pm
poniday wrote:Any advice on how to pry off a 2 year old (o-ring) seal without taking off your finger(s) or losing an eye?
If your dispersion screen has a screw in it, take it out and get the dispersion block out, too. If your's is like my LP, the screen is held in by said gasket.
Another trick, especially handy if the water in the machine is not heated yet, lock in the PF and run the brew water. As soon as it comes up to pressure, slowly unlock the PF. The water pressure may get under the gasket and push it out a bit as it follows the PF down. It can take a couple tries. It doesn't always work. If the machine is hot, be careful with the scalding thing. It hurts, and can scar. That being said, I've never burned worse by not paying too much attention to the steam wand. It will burp, but, (and again, depending on your machine) it shouldn't explode. This does not mean that you shouldn't exercise caution. You're pulling the PF off while it is still being pressurised by the pump with this. If you turn it off during the process, all the pressure goes out the three-way valve.
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Link to "Advice on grouphead gasket removal needed"by Randy G. on Sat May 24, 2008 6:56 pm
Try this: I will assume that the gasket is quite hard. Get two drywall screws. File or grind the end off of one of them so that it is quite flat. Stat one onto the gasket until it just touches the brewhead. Remove it. Now insert the other into the same hole and continue on when it touches the brew head. Keep turning it until it pushes the gasket part-way out or until it strips. If it strips, do it again near the first. Continue until the gasket breaks there, then pry it out with a small chisel or similar tool. If it moves, pull on the screw with a pair of pliers. Etc.
Bought to you by VODKA! It's not just for breakfast any more! (it's been a long day...)
Espresso! My Espresso!
Randy G.
Return to Espresso Machines
