Adjusting espresso machine's rotary pump brew pressure?
Link to "Adjusting espresso machine's rotary pump brew pressure?"by dawgcatching on Fri Jan 27, 2006 1:56 am
Hi there,
How do I adjust the pump pressure on the Bric? I have a PF-mounted gauge handy. I assume I take the shell off (not sure how to do that either) and then, where is the pressure adjustment screw? To lessen the pressure, do I turn the screw in or out? Also, should I use an in-line pressure regulator? I notice the brewing water tends to pulse as the Flo-Jet is cycling. Thanks!
dawgcatching
Link to "Adjusting espresso machine's rotary pump brew pressure?"by miKe mcKoffee on Fri Jan 27, 2006 2:08 am
Cover removal first take off the the top (cup warming area), 3 phillips screws. The body wrap is held on by one flathead screw on the outside back, two hex top inside front, then lift straight up. (has to 'ears' that slide out of slots bottom front) As you're facing the Bric', pump pressure regulator is on the left hand side just behind end of the boiler. The adjustment screw faces towards the front and upwards about 45 degrees from horizontal, right by the boiler, was a bit tricky to get at on mine but not too bad. Adjust in small increments.
Not using a Flojet so no suggestion there.
miKe mcKoffee
Link to "Adjusting espresso machine's rotary pump brew pressure?"by barry on Fri Jan 27, 2006 10:34 am
dawgcatching wrote: I notice the brewing water tends to pulse as the Flo-Jet is cycling.
get an accumulator
barry
Link to "Adjusting espresso machine's rotary pump brew pressure?"by malachi on Fri Jan 27, 2006 11:16 am
What Barry said.
malachi
Link to "Adjusting espresso machine's rotary pump brew pressure?"by HB on Fri Jan 27, 2006 1:26 pm
What Barry and Chris said, to which I'll add a picture and link:
Shurflo accumulator from espressoParts.com
Adjustments are performed at the pump screw as Mike describes (clockwise = higher brew pressure).
Link to "Adjusting espresso machine's rotary pump brew pressure?"by dawgcatching on Fri Jan 27, 2006 6:00 pm
Thanks for the tips! I will tear it apart tonight. Do you think the higher (12 BAR) pump pressure that I am running is causing some excess channeling? On my bottomless PF, I notice that the rim of the basket sees extraction about a second before the extraction seeps through the center of the basket. The extract appears as a 1cm-wide ring and then fills in across the entire basket. I am hoping that a bit lower brewing pressure will not force open the inherent weakness of the coffee/basket interface as much, and make for a more even extraction. What do you think?
dawgcatching
Link to "Adjusting espresso machine's rotary pump brew pressure?"by malachi on Fri Jan 27, 2006 6:42 pm
12 BAR?!?!?!
Umm... that is really high.
suggest dropping to 8.5-10 BAR.
malachi
Link to "Adjusting espresso machine's rotary pump brew pressure?"by HB on Fri Jan 27, 2006 9:54 pm
dawgcatching wrote:Do you think the higher (12 BAR) pump pressure that I am running is causing some excess channeling?
I raised the pressure to 11 bar to produce this beauty:
System meltdown from Perfecting the Naked Extraction
Just the other week a group of locals and I were checking out the La Marzocco GB5 at Counter Culture Coffee's espresso lab. The shots were not coming together... they were marginally drinkable. Looking at the brew pressure, I see it's edged up to 10.5 bar. A quick reduction to 9 bar and magically we were back in the groove. So yes, it definitely makes for an easier extraction.
Link to "Adjusting espresso machine's rotary pump brew pressure?"by dawgcatching on Sat Jan 28, 2006 2:00 am
I hooked up the pressure gauge attachment to the PF tonight to check the pump pressure (I was told that it was not adjusted at 1st-line). To my surprise, the gauge read 8.9 BAR. But, seal around the grouphead gasket wasn't great, and it was squirting water out, despite my best efforts at tightening it. Do you think that my pressure is close to 9 BAR, or am I losing 1-2 BAR with the bad seal? How the heck can I tell what the real pressure it, or can I somehow estimate it?
dawgcatching
Link to "Adjusting espresso machine's rotary pump brew pressure?"by HB on Sat Jan 28, 2006 7:37 am
dawgcatching wrote:Do you think that my pressure is close to 9 BAR, or am I losing 1-2 BAR with the bad seal? How the heck can I tell what the real pressure it, or can I somehow estimate it?
Given a rotary pump's high flow rate, some dribbling won't affect the displayed pressure reading. I cannot say if a "mini-geyser" would invalidate the reading entirely.
Link to "Adjusting espresso machine's rotary pump brew pressure?"by dawgcatching on Sat Jan 28, 2006 11:26 am
HB wrote:Given a rotary pump's high flow rate, some dribbling won't affect the displayed pressure reading. I cannot say if a "mini-geyser" would invalidate the reading entirely.
Thanks-I figure that am losing maybe 1oz over a 12-15 second pull with the gauge. I wouldn't be surprised to find that my reading ended up .5 BAR off. Still, that would be within target (about 9.5 BAR).
The picture you posted of the naked extraction "beauty" shot: was that tongue-in-cheek, or is that what a good naked shot looks like? Most pics I see are of a single stream, although mine look just like your picture when starting out (1st 8 seconds).
dawgcatching
Link to "Adjusting espresso machine's rotary pump brew pressure?"by HB on Sat Jan 28, 2006 12:11 pm
If it's dribbling only one ounce in 15 seconds, the reading is trustworthy. True "dead head" readings on a rotary pump creep up. Bob explained how to get a more accurate reading in Help with La Cimbali Jr.:
bobroseman wrote:It seems to me that if your going to measure brew pressure and make adjustments, then you need to know the exact pressure that you have while pulling a shot. Most portafilter gauges measure only the static pressure at the brew head when the by-pass valve has opened. That is not the pressure you are getting when you are brewing espresso. The attached photo is a simple mod I made to the gauge I bought from Chris Coffee. I can adjust the needle valve to allow precisly 2 oz of water to flow in 25 seconds while reading the pressure. On my machine, the resulting pressure is 8 bar, as seen in the inset.
Bob
here it is in use:
As for the "beauty shot" I posted earllier, the article explains that it's beautifully flawed. There's gigabytes of pictures of proper extractions posted on the Internet, but in my opinion, there's not enough instructive improper extractions.
Link to "Adjusting espresso machine's rotary pump brew pressure?"by matt on Tue Jan 31, 2006 11:51 pm
Indeed, I've had a lot of shots like that. I've been berating myself for my distribution (and in truth, a lot of it was probably deserved) but I finally got around to checking today and yes, my Bric was at 11 bar.
Now, that's 11 bar with a grouphead gauge with no needle valve. When folks say "8.5-10 bar" as ideal, is that the measurement they mean? Or should I mentally add a bit to that 8.5-10 bar to compensate? If I was letting through 2 oz. in 30 seconds, then my reading would be somewhat lower, but I sure don't know how much.
Perhaps there's some bright side of having it too high for a while -- I feel a bit better that, if I can distribute enough to not channel under very high pressure, perhaps I'm well-trained to do it at 9.25 bars. Like training for track meet with a weighted vest. Maybe.
matt
Link to "Adjusting espresso machine's rotary pump brew pressure?"by HB on Wed Feb 01, 2006 6:58 am
matt wrote:Now, that's 11 bar with a grouphead gauge with no needle valve. When folks say "8.5-10 bar" as ideal, is that the measurement they mean? Or should I mentally add a bit to that 8.5-10 bar to compensate?
The reading I've seen on a rotary pump from such a (non bleeding) gauge will "creep" upward, so it's hard to generalize about the static versus dynamic brew pressure. You'll get a more accurate reading if there is even a tiny flow. In a pinch I've loosened the portafilter gauge slightly so it drips and that's enough for a steady reading (of course don't loosen it too much or you may get sprayed!).
Link to "Adjusting espresso machine's rotary pump brew pressure?"by Grant on Wed Feb 01, 2006 4:03 pm
On my Bricoletta (after adjusting the pressure), with a fluid filled gauge directly on the PF and no leakage at all, it reads a little over 9 Bar, and does not seem to creep up at all...the gauge goes from 0 - 9 bar in a few seconds, and doesn't move from there...at least in the amount of time I have left it (about 15 seconds maybe).
Grant
Grant
Link to "Adjusting espresso machine's rotary pump brew pressure?"by matt on Wed Feb 01, 2006 4:48 pm
Sounds good. I didn't remember seeing any creep on my gauge (on a Bricoletta), but I figured I may not have watched it long enough.
I'm not in front of the machine now, but unless someone corrects me, I'll plan on using the reading from a sealed gauge if it's holding steady, and giving it a bit of a leak if it creeps upwards.
Thanks a lot, guys.
matt
Link to "Adjusting espresso machine's rotary pump brew pressure?"by RapidCoffee on Wed Feb 01, 2006 4:58 pm
Grant wrote:On my Bricoletta (after adjusting the pressure), with a fluid filled gauge directly on the PF and no leakage at all, it reads a little over 9 Bar, and does not seem to creep up at all...the gauge goes from 0 - 9 bar in a few seconds, and doesn't move from there...at least in the amount of time I have left it (about 15 seconds maybe).
My experience mirrors that of Grant. On two different rotary pump machines, using a nonfilled PF gauge and blind filter, the pressure reading ramps up to the max setting (9 bars) over a few seconds and then holds rock steady. I'm getting approximately the same reading on my builtin Vetrano pressure gauge (hard to read with any precision, the markings only run 0, 8, 12, and 15 bars), perhaps a bit less under typical espresso flow.
RapidCoffee
Link to "Adjusting espresso machine's rotary pump brew pressure?"by dawgcatching on Sat Mar 25, 2006 11:30 pm
I FINALLY got the Shurflo accumulator installed (I was over in Japan for awhile, which is another story (amazing drip coffee (made to order), horrible espresso). Getting the required installation parts locally was a pain: I had to use a bunch of fittings and runs of the 1/4 tubing to connect them all, as the local Home Depot didn't have what I needed, and they have run all of the plumbing places/hardware stores out of business.
The water hammer is definitely gone, but I am getting the pressure creep mentioned above. After pressurization (3 seconds or so) the pressure gauge comes right to 9.25 Bar, then keeps slowly heading up, to 12 Bar in about 20 seconds.
Isn't the whole point of the pressure adjustment to adjust a blow-off valve? Therefore, the pressure cannot move past that point? If so, why am I heading above that pressure (up to 12 Bar)? Or do rotary pumps work differently than Vibe pumps?
Also, is there any way to somewhat estimate my likely ristretto brew pressure without having to buy the flow regulator kit that Bob mentions above? Close would be good enough: I am not that worried if the brew pressure is reading 9 when it is actually 9.5 Bar at this point, but if I am seeing 9 Bar and the actual brew pressure is only somewhere between 6 and 12 Bar, it doesn't tell me much.
dawgcatching
Link to "Adjusting espresso machine's rotary pump brew pressure?"by HB on Sun Mar 26, 2006 12:41 am
dawgcatching wrote:Also, is there any way to somewhat estimate my likely ristretto brew pressure without having to buy the flow regulator kit that Bob mentions above?
Didn't I respond to this earlier?
HB wrote:You'll get a more accurate reading if there is even a tiny flow. In a pinch I've loosened the portafilter gauge slightly so it drips and that's enough for a steady reading (of course don't loosen it too much or you may get sprayed!).
You can also measure it while pulling a shot.
Link to "Adjusting espresso machine's rotary pump brew pressure?"by dawgcatching on Sun Mar 26, 2006 10:23 am
Sorry, I missed the end of that earlier reply. Hey, it was late on a Saturday night, give me a break.... :D
The good news is with that Shurflo accumulator, things are MUCH improved already. The occasional little squirties that I used to get with a bottomless double (and which seemed to accompany nearly every shot, good or bad) have disappeared. Plus, my FloJet isn't kicking on and off every 5 seconds. Thanks everyone!
dawgcatching
Return to Espresso Machines
