So I will say that i do like the Rocky/Anita setup after 3 hours of trial and error (AND WAY TOO MUCH BLACK CAT!). After 1/3lb of beans I decided to step the brew pressure down a bar to the 9.5 bars, once I did that the shots seemed to come a lot easier. I did end up making a lot more terrible espresso then good espresso this evening, but I am getting better and most of the shots are average at this point.
In terms of the Rocky, I can now see the advantages of a doser, but I wanted something flexible enough to grind for press without much hassle. I think distribution is a minor issue because the grinds are a tad clumpy, but finding a good routine and a good consistent tamp doesn't seem to be that difficult. Finally, I think the portafilter rest is a little too high and I take it out sometimes as it seems to make distributing the grounds easier when there is more maneuverability. It is the nicest grinder I have ever owned and it seems to have a very fine grind difference between steps, but I may long for a stepless grinder very soon.
Its been a fun day and I think I will love this new setup. I have waited a very long time so I could build up the gumption to buy a good machine after my Delonghi died 4 years ago. For the money I am very satisfied with my purchase and think I will be able to teach myself a lot about espresso in the next few years.
My new toy:
I think the fingerprints on the machine show its being used, but all that chrome not being shiny may drive my wife nuts. I had no idea how much this machine would dominate the landscape of our fairly good sided kitchen.
-LH
mineralman55 wrote:Use it for an evening or two before you begin fooling with it. Get used to it, see where the brew pressure is when making shots, assuming you're getting the grind and tamp right. After that, turn the pressure down (or up as the case might be) about 1/4 to 1/2 turn of the nut, then button up the Anita and brew a night or two. It will take a few heating/cooling cycles to equilibrate again. I had to turn my Anita down from a factory setting of 12.5 bars brew pressure to now 9.5 bars. It makes quite a difference.
BTW, let me know ASAP how you like the Rocky/Anita combo.
Larry
New Orleans
