by stevendouglas on Thu Aug 03, 2006 7:59 pm
My home setup includes a Mazzer Mini-E and one of the features I appreciate about this grinder is the timer. While I have to tinker with the timer every other day or so, after I get that dialed in, I shove the PF under the chute a couple of times and I've got the right dose. It's all good.
I've just ordered the Quick Mill Stepless from Chris' for decaf coffee at home and there is no timer on it. I would like to install a timer on the Quick Mill grinder.
Has anyone installed a timer on a grinder? I looked online and couldn't find a 120V timer that was adjustable in seconds (probably 5 seconds to 30 seconds). An LED count-down timer would be ideal. While I'm an EE, I don't want to, nor COULD I if I wanted to, design and build a timing circuit from the ground up.
Any help would be appreciated. (Yes, I realize it would be easier all the way around to just weigh my beans and grind to completion. That's not the point of this exercise.)
Thanks,
Steve
Steve Douglas
Sacramento, CA
