220V timer for nema type plug (30 amp)
Link to "220V timer for nema type plug (30 amp)"by woofhead on Tue Mar 27, 2007 6:38 pm
Hi,
I'd like to put my machine on a timer-it's a cimbali m30 and is 220, using a nema type plug(30 amp) and the pin config is 14-30.Has anyone used a plugin or wired timer they can recommend? I'd prefer not to use a timer at the breaker box as it's 2 floors away and I'll change the start times pretty often as I work all different hours and sleep at various times and want to have the machine come on 45 min before I wake.Thanks,
Mike
woofhead
Link to "220V timer for nema type plug (30 amp)"by woofhead on Tue Mar 27, 2007 6:41 pm
oh yeah,
I'm not against going with another plug/outlet format if that makes more sense.tanks!
woofhead
Link to "220V timer for nema type plug (30 amp)"by jesawdy on Tue Mar 27, 2007 7:33 pm
This might work....
Intermatic HB114C, see here or here.
Here's the spec sheet - http://www.intermatic.com/images/misc/HB114C.pdf
Jeff Sawdy
jesawdy
Link to "220V timer for nema type plug (30 amp)"by cannonfodder on Tue Mar 27, 2007 11:20 pm
If that is a two group M30, you may want to revise your warm-up time. A commercial box takes closer to an hour, minimum to completely heat. I give my two group Faema an hour and a half before use.
cannonfodder
Link to "220V timer for nema type plug (30 amp)"by woofhead on Wed Mar 28, 2007 6:21 pm
will I need to use a surge suppressor after the timer? Thanks,
Mike
woofhead
Link to "220V timer for nema type plug (30 amp)"by jesawdy on Wed Mar 28, 2007 8:56 pm
I just realized you were asking for a 30A timer. I wanted to add that the timer I linked to is only rated at 20AMPS, but 5000 Watts, so YMMV. How many watts are you pulling? I would think at 240V, you wouldn't be over 20A, but I may be wrong.
Jeff Sawdy
jesawdy
Link to "220V timer for nema type plug (30 amp)"by woofhead on Wed Mar 28, 2007 10:44 pm
That plug that's on the machine (nema 14-30)is rated for 30 amps but I'm sure that timer you told me about will be fine.I looked around and it seems like the perfect thing and not too expensive.I'll just change the plug and outlet to match and try it out.
woofhead
Link to "220V timer for nema type plug (30 amp)"by woofhead on Thu Mar 29, 2007 10:07 pm
howdy,
changed the plug and receptacle today and will order the timer tonite.Thanks again!Lovin the machine-shots getting better all the time and the grinder is cleaning up well too.
Mike
woofhead
Return to Espresso Machines
