I did play with some different gicleurs I've made. I've got some M5 plugs and I drilled and tested 0.40mm, 0.60mm and 1mm!
The original gicleur, at least on my machine, is 0.90mm. The dwell time and pressure ramp is great with 0.60mm, almost too slow, maybe it could be better with 0.70mm too, but it takes forever, more than 10 seconds, to flush the boiling water.
So I've focused on the temp management and I'm using the 1mm gicleur. The dwell time and pressure ramp change very little and it takes between 6 to 7 seconds to flush the boiling water compared to the original 8 to 9 seconds. Without gicleur it takes 5 seconds or less to flush the boiling water. The pressure gauge is around 1.1 bar. I'm locking and pulling the shot as soon as possible after the flush. The temperature profile is almost flat.
On the pressure and pump side, I was getting that weird behavior others had with vibe pumps, where it was dropping pressure some times, from 12 to 6, for instance. I've opened and cleaned the pump, but the mushroom valve is deformed. Anyway, now it's working, maybe it was some dirty from the valve and some misplacing, besides the deformation.
But one strange fact is that now I'm getting max 12 bar (no flow). It takes to 12 bar and rises just to 12.5, never reaches 13 bar. I did compress the piston spring (the one that push it when the solenoid is off) but I was not expecting to deform it - but I'm not sure this is what happened. Maybe it's a talk to specific pump thread...
Márcio.
