www.ajcoffeeco.com: excellent coffee without compromise
Banish Uneven Extractions with Weiss Distribution Technique - Page 4
Postby TimEggers on Sat Mar 15, 2008 11:47 pm
TimEggers wrote:John,
Again I must thank you so much for sharing this practical approach. It has been the single best advantage I have had learning home espresso. It's amazing that the WDT and a bottomless portafilter have in such a short time given me truly amazing espresso at home.
My shots bead so evenly and espresso is truly beautiful. I owe my progress to the WDT, it remains the single most important tool for the budding home barista to quickly and effectively establish a consistent technique.
I owe my greatest shots to the WDT.
(now if my espresso wasn't so darn good I wouldn't drink so much of it!)
Thanks John! :D
Well it's been a year. I tried to wean myself from the WDT and got some pretty good results. Still though nothing matches the consistency of the WDT. I tried everything and practiced practiced practiced. Sure I got great shots some of the time, good shots most of the times but nothing in my experience makes great shots as effortless than the WDT.
I'll admit I loathe the use of the yogurt cup so I just stir the grounds in the portafilter and you know what? Five seconds of that does the trick on my pours just fine. I like the adaptability of this method and the way it makes exceptional espresso easy. Beautiful pours that taste good without any thought or effort (within reason). The WDT has taken a lot of distribution stress away from me that's for sure.
I used to think that a "real" barista doesn't need the WDT, in truth the real barista strives for the finest espresso quality. For me that's WDT. Well done John, I guess I'm a reconvert! :wink:
TimEggers
Postby RapidCoffee on Sun Mar 16, 2008 6:32 pm
TimEggers wrote:I used to think that a "real" barista doesn't need the WDT, in truth the real barista strives for the finest espresso quality. For me that's WDT. Well done John, I guess I'm a reconvert! :wink:
Many thanks for the kind words, and I'm always glad to hear it's helping someone. I would never claim that anyone "needs" to use the WDT, but I believe it does improve my pours by (in Tim "cajun_brew" Brunson's words) eliminating one of the variables: in this case, distribution errors.
John
RapidCoffee
Postby TimEggers on Sun Mar 16, 2008 9:54 pm
RapidCoffee wrote:Many thanks for the kind words, and I'm always glad to hear it's helping someone. I would never claim that anyone "needs" to use the WDT, but I believe it does improve my pours by (in Tim "cajun_brew" Brunson's words) eliminating one of the variables: in this case, distribution errors.
Precisely. What I was meaning to say was that I've had some illusion in my pea brain of a master artist making the coffee with fluid smooth cinematic movements. Then locking in the portafilter and getting a smooth still stream of pure honey joy.
I was wrapped up in a silly notion of what a barista is supposed to look like when making espresso. I'll hand it to the guys and gals that can grind dose tamp and pull excellent shots without even thinking about it each and every time.
I can't. That's why I love the WDT. With it I can, each and every time. Nothing has made me more consistent than the WDT. It's a very practical solution to the most common problems in the most important aspect of home espresso: distribution.
TimEggers
Postby Canuck on Fri Apr 11, 2008 1:50 pm
Has anyone found something other than a yoghurt cup, that fits standard 58mm baskets? I was thinking that if the item was metal, or of another material that reduces static, it might help? Though I guess if you stir up the grounds afterwards you're removing clumps anyway...
Canuck
Postby shadowfax on Fri Apr 11, 2008 2:07 pm
Canuck wrote:Has anyone found something other than a yoghurt cup, that fits standard 58mm baskets? I was thinking that if the item was metal, or of another material that reduces static, it might help? Though I guess if you stir up the grounds afterwards you're removing clumps anyway...
I would be interested to hear if there were something off the shelf that would fit like a yogurt cup, but I will say that metal is often not all that anti-static. I learned this with that darned expensive Mini-E chute that I bought for my old Super Jolly. the chute did absolutely nothing in terms of reducing static, even when I grounded it pretty thoroughly.
On my current mini, which really only has the safety features removed and the doser sweep mod, the best way that I have found to reduce static is to let the grinds sit in the doser for 10-20 seconds while I brush out the chute and then brush the upper portions of the inside walls of the doser. This proximity of the bristles of my brush, as well as the "resting" time that the grinds get while I am meticulously brushing, seems to neutralize most of the static. Of course, after I do this I really thwack the doser ridiculously hard (I have to hold the mini down while I do this) to break up the clumps. This probably doesn't matter much, since I still use a combo of WDT and the Stockfleth's move to distribute and level, but I do it anyway. With the yogurt cup and the brush method above, I really have no issues with static. I would still like to find an alternate to the yogurt cup though, as it is kind of an ugly tool compared to the other things I use to prepare my coffee...
Nicholas Lundgaard
shadowfax
Postby HB on Sat Apr 12, 2008 9:01 am
shadowfax wrote:I would still like to find an alternate to the yogurt cup though, as it is kind of an ugly tool compared to the other things I use to prepare my coffee...
You have a point, a cutoff yogurt cup doesn't have the "Blue Steel" look of my other gear. One option, if you're serious, is to ask a machinist to make one out of brass. Once they stop laughing, they could toss a stock billet on the lathe and cut a nice custom-fit groove for the basket on a flared cylinder. With a little polish and a few coats of clear lacquer, you'd have the sharpest looking WDT cup on the planet.
Postby RapidCoffee on Sat Apr 12, 2008 4:04 pm
I keep hoping someone with an entrepreneurial bone in their body will start marketing a WDT Toolkit. (Ain't gonna be me. :P)
John
RapidCoffee
Postby Canuck on Wed Apr 16, 2008 3:09 pm
For those using this technique, after stirring the grounds do you then use one of the traditional distribution techniques (n,s,e,w, stockfleth, nutating, etc.) or do you just level off the grounds with a flat edge (and if just a flat edge, do you make an x sweep, 2 sweeps from the centre, etc.)?
Seems to me like a silly, nitpicking question, but I find that the more I do the more can go wrong.
My current technique: after stirring the grounds, I remove the yog container, tap the basket down lightly on the counter, then do a n,s,e,w twice (2nd time pushing grounds off the basket). I then light tamp, ensuring the tamp is even, then a light nutating tamp, then a 30# tamp (happens faster than it might appear). I've found after introducing the nutating tamp things got more consistent...
If I thought it would work as well, I would prefer to just sweep/level the grounds with say the back of a knife (after tapping the basket lightly on the counter?), followed by a light tamp then 30# tamp. I think (many months ago) I tried this but found that after tamping, the puck didn't compress far enough into the basket and it would often touch the shower screen when I locked in the PF. I guess my n,s,e,w means less coffee in the basket...
Thanks.
Canuck
Postby RapidCoffee on Wed Apr 16, 2008 4:46 pm
Canuck wrote:My current technique: after stirring the grounds, I remove the yog container, tap the basket down lightly on the counter, then do a n,s,e,w twice (2nd time pushing grounds off the basket).
If you're overdosing, then do not tap ("thump") the basket. This is a very effective updosing technique (see e.g. this thread). A downwards tap after leveling the grounds will not affect the dose, but thumping with a mound of coffee in the basket will certainly cause updosing.
I typically do a sweep to level the basket. To downdose slightly, you can stir the grounds after leveling and sweep again. If the grounds are evenly distributed and you're using a straight edge to level, I don't think it matters much whether you use one leveling sweep or two NSEW sweeps.
John
RapidCoffee
Postby Canuck on Fri Oct 31, 2008 10:53 am
Not sure if this has been debated here or on CG...assuming I have no 'convenience' issues with using the WDT as part of my routine, does a dosered grinder offer any advantages over using the WDT (e.g. does the doser do a better job of removing clumps vs. WDT, etc.)?
I've heard the Macap doserless, for example, grinds 'rocks'. But if I dose into the basket then apply WDT, would the grind 'quality' be = to the dosered Macap (if not, why would it differ)? I know most people wouldn't own both grinders, so an objective opinion may be hard to find...but I figured I would ask.
Canuck
PreviousNext
Return to Article Feedback
