The thermosyphon PID monitors the temperature of the group near the thermosyphon output port. It modulates the thermosyphon flow by switching a custom made valve mounted on top of the group. When not energized the valve blocks the thermosyphon inlet port and consequently limits the heating of the group. This control loop works quite well and can regulate the temperature within one degree. The thermosyphon valve is also interlocked with the group switch, causing the valve to close during a shot. This prevents the hot water at the top of the thermosyphon loop from entering the group during the shot.
A second PID measures the shot temperature using a thermocouple that is positioned right at the shower screen. If the shot is too hot it turns on a second solenoid valve that allows a small amount of cool water to bypass the heat exchanger and directly enter the group. I drilled a hole in the back of the group between the thermosyphon ports and attached a 1/8" line for the water injection. This control loop is a little harder to stabilize because of the transport delay from the injection port to the point where the temperature is measured. As long as the shot flow is around 100 ml/min the PID seems to do a pretty good job, settling out within a few seconds.
I know that with experience the shot temperature can be controlled by the proper flushing routine, but hey, what am I to do with this box of PID controllers?
