I'm really curious about this. On my T1, the group idles at 211 degrees when completely stabilized (running the boiler at .8 - 1.0 b and measuring at the "port"). If I reduced the thermosyphon flow to the point that it idled at, say 204, I would reduce the cooling flush noticeably because the brew water would not leach as much energy from the group mass, correct? How would this lower group temp effectively increase recovery time?
Certainly you would reduce the cooling flush requirements-- I agree with that. As regards recovery time, a better statement on my part would have been that you increase the recovery time relative to the particular machine in question. As the OP has a Quick Mill Anita (as do I), my response was inherently slanted towards that line of machines (Anita, Andreja, Vetrano). Whether or not it is a correct answer for an Elektra T1 is, perhaps, up for grabs, with a tilt towards me being incorrect-- and here's my take on why. Saying this with a slight smile "I don't believe a machine that has a 6 liter boiler and 2000 watt heating element has any problems whatsoever with "recovery" that would be better applied to the human side of the PF as said human is trying to keep up with the Elektra's capabilities before keeling over in a pool of sweat.
The same cannot be said for the Quick Mill machines at their normal(?) pstat settings of 1.10 to 1.25 bar (maximum gage readings) and, if they were set to duplicate your setting of 0.80 to 1.00 bar (min to max), ya better grab a pillow.
When I said "there is no such thing as a free lunch", I meant that you would need to sacrifice some in the ability of the machine to pull rapid consecutive shots. If you have a machine that can do this rather easily with no modifications (Elektra), you sacrifice nothing(?). On the other hand, if the machine is either hard pressed to accomplish this or simply cannot, I believe a thermosyphon flow reduction will penalize that particular aspect of the machine's performance (recovery).
Shouldn't the Hx water heat back up to boiler temp at the same rate as before the mod?
I don't think so because you are inherently inputting less energy into the boiler as would be evidenced by a reduced total "on-time" for the heating element. The amount of energy you need to put into the boiler (steady-state idle) is governed by the heat loss to the environment by the grouphead, the thermosyphon lines, and the boiler itself. The major change the mod makes is in the temperature of the grouphead -- as it was supposed to do. While it surely varies from machine to machine, idle condition hx outlet temperature is about 15-20 degrees less than AVERAGE boiler temperature.
At the end of the shot, wouldn't the group head be relatively close to brew temp, or likely somewhere between high idle and brew temp?
At the end of a shot, Anita's grouphead temperature goes below desired brew temp because, at least momentarily, a reverse thermosyphon action takes place. A lot of this will also depend on the technique used to pull the shot. The size of the hx in Anita is small -- 110 ml.
From what temp profiling I've done, it appears that the group mass itself actually changes relatively little during brew activity, whether it be cooling flush or pulling a shot. Granted this was measured on the outside surface of the group head, not in a well, for instance. But I don't understand why you would need the "recovery" to (in my case) 211, if that's what's implied by your statement.
I kinda believe the Elektra is designed for a more rigorous duty cycle than Anita or her siblings. It would be interesting, of course, to compare Elektra's flushing temperature "curve" to Anita after agreeing to a specific baseline and flushing volume. But that would just be for fun -- I don't think anything could be gleened from the comparison. I also believe Elektra's grouphead has a little more mass than the standard E61 which would buoy your statement as regards temperature changing very little.
I don't believe you "need" the recovery to 211 but if you really wanted to compare apples to apples, you should judge the recovery time back to the original starting point, whether it be 211 or 204. If the Elektra (or any machine for that matter) can demonstrate EQUIVALENT performance under a strenuous duty cycle but at a lower grouphead temperature, then I would reach the conclusion that the Elektra's engineers should have kept the lights on a little longer. Or perhaps there is something that I am missing . . .
I just don't see how there would be any detriment to keeping the group internal temp closer to the target brew range, as long as you didn't reduce the group idle temp to the point that it's below the target brew temp, and any temp above that would really be wasted thermal energy.
Well, I would have to say you are correct for a particular class of machine, e.g. the Vibiemme Domobar has a 2.0 mm restrictor (dealer applied) to the hx outlet and I have seen zero complaints from owners re pulling multiple shots. If you do a search on A.C. for posts by Greg Scace (keyword = thermosyphon), you will also see where he increased the length of his hx outlet line (by a factor of 3) and succeeded in reducing the group temperature of his Astra from the low 200s to 198.
