akallio wrote:Because there is some offset between boiler temperature and brew temperature, brew boilers can go above 100 C. However I am not sure what happens when brewing starts. Opening the passage from boiler to the group should release the pressure and drop temperature to 100 C, but on the other hand pump starts to push in new water and the system is quickly pressurised again. I guess there is more than 100 C in the boiler when brewing, because machines with several degrees of offset are still capable of producing boiling brew water. Non-pressurized kettle would thus limit the maximum brew temperature, but not necessarily too much. Or I might be completely wrong here...
Another issue is that the pump should be capable of handling boiling water, because pressure needs to be created after the kettle. And there needs to be another pump for filling the kettle. Maybe having a pressurised boiler is not that bad after all?
But I had suggested an unpressurized kettle, not a boiler under pressure, for the brew water, with temperature set precisely for desired brew temperature. The thermoblock would only have to raise the temperature from brew temperature to vapor, not from room temperature or colder mains temperature.
You don't need boiling water to produce espresso. The pump would create the brew pressure. As for filling the kettle, that could be done under mains pressure.
