When does a Semi become a Super? - Page 2
- Compass Coffee
An automatic that can also be run as a semi-automatic, which is the norm.Psyd wrote:What is it if it has a switch and volumetric dosing buttons? A semi-semi-automatic? Demi-automatic? Selective-fire machines? ; >
Mike McGinness
- Psyd
It's been my experience (small as it is, and most very possibly inaccurate, too) that most semis have an on-off switch (or, off-pre-on) of some sort, and autos have a set of dose switches. Mine has both, a set of programmable volumetric pads and a separate on-off switch.Compass Coffee wrote:An automatic that can also be run as a semi-automatic, which is the norm.
Or have I just not been paying close enough attention?
Espresso Sniper
One Shot, One Kill
LMWDP #175
One Shot, One Kill
LMWDP #175
- Compass Coffee
Exactly. My Linea(s) are the same. Programmable volumetic touch pads and manual on/off rocker which allows manual usage should the brain fry. With Linea one of the pads is also manual mode toggling group flow on/off. Whether manual operation is with a mechanical or touch-pad type switch doesn't matter, manual on manual off makes it semi-automatic operation. If a particular auto machine didn't have a manual mechanical or pad switch no biggy, program one of the switches for an absurd amount forcing you to either manually stop the shot or end up with a quart or more of foul brown liquid!
Mike McGinness
- Psyd
Yeah, a second push of any volumetric button stops it where it sits.Compass Coffee wrote:program one of the switches for an absurd amount forcing you to either manually stop the shot
Odd, the last time I had this conversation, it seemed that both were 'unheard of' and rather rare. I haven't done any research or anything, or paid that awful much attention to other volumetric dosing machines, but just other espresso hounds and their machines.
I did notice them on the GB5 when I got to play with a couple of them along the way, but other than the Astorias, I haven't noticed any others.
I bet I see about a hundred of them in the next month, though!
Espresso Sniper
One Shot, One Kill
LMWDP #175
One Shot, One Kill
LMWDP #175
- shadowfax
My Elektra looks like this:
Image source: CafeParts.com
I believe this is an old La Marzocco Linea panel:
That eagle/star/squiggle/program button is pretty typical of automatics from what I've seen:
On my Elektra, it initiates programming mode when the key is turned to programming mode. However, in day to day usage, pressing it activates brewing, and it operates continuously till that button is pressed again. I understand there are variations (sometimes it's the universal "early stop" button for the panel). I'm curious how they work on your average "machine that's not mine." IIRC the Astoria Gloria programming button works as I've described, but it's been awhile since I used one.
Nicholas Lundgaard
- Psyd
The Astorias have a separate hidden switch to program, under the warming tray. They also have a separate, manual, physical, lighted on-off toggle for each group, that turns the group on and off.shadowfax wrote:IIRC the Astoria Gloria programming button works as I've described, but it's been awhile since I used one.
It's an entirely separate semi-automatic set-up, with an automatic setup next to it. It's just ever so slightly different from using an auto in semi fashion. If the auto membrane switch pad were removed and disconnected, I could still use this as a semi. It's as if a semi-automatic machine had an automatic setup added to it.
Espresso Sniper
One Shot, One Kill
LMWDP #175
One Shot, One Kill
LMWDP #175
Let's not forget "manual" in terms of pump-driven machines . . . also known in some circles as a "levetta," not to be confused with a "manual lever" machine, as opposed to a "spring-operated lever machine."
So in the world of pump-driven machines, we really have:
- Manually-operated "levetta" machine (example);
- Semi-automatic machine (example);
- Automatic, aka Volumetrically-dosed, machine (example -- 2nd picture from the top); and
- Super-automatic machine (example).
- Compass Coffee
True enough. Though some A's are actually just B's with the levetta activating the switch while other A's have attributes B's lack - manual line pressure pre-infusion in mid position. Then there are paddle groups which could be considered levettas top group mounted versus E61 style...
Mike McGinness
