by JmanEspresso on Wed Sep 23, 2009 12:20 am
Simple fix, simple to replace, choice is yours.
you might try fiddling with the little "stick" which pokes up when the vac-breaker seals. Mine was malfunctioning a little while ago, and I bought a new one. Before installing it, I played around with the old, JUST as it was about to seal.
As pressure was building, the stick popped up, but still leaked pressure. I just fiddled it around, and it popped up a bit further. Been working ever since.
Taking it off is relatively easy.. You will probably need a deep socket to reach the bottom of it.. I did at least.
Chris' Coffee sells two different Vacuum Breakers. He has a small, "standard" one, which will fit if there is very low clearance inside. The other one is bigger, but there is a barb connection on the top of it, so you attach tubing to it, and run it somewhere, so any water spits don't spit on electronics or anything like that.
