What's a "coffee pod adaptor"?
Postby rfc on Tue Aug 30, 2005 4:10 pm
My mini grimac has a 2-1/2" diameter brass circular thing so named, with the screen in the middle. In the parts list it shows a smaller diameter "water diffuser" that seems to be standard.
What is the Pod adaptor, and should this be the thing I should be using. There is a photo of it in the thread "mini grimac...scale buildup" (or something like that.
rfc
Postby HB on Tue Aug 30, 2005 6:01 pm
The famous pod adapter is shown to the far right:
La Valentina and apparently your machine come stock with this funky dispersion screen. It allows them to serve double-duty as a somewhat pod-friendly espresso machine and also use traditional loose grounds. Or at least in theory. The idea is to reduce the head clearance enough that the water doesn't channel around a double-pod stuffed into the stock basket. A friendly lurker offered some samples for me to try, and as expected, it was typical pod espresso: Weak, devoid of body, and bitter. If you added enough milk though, it was better than our office coffee.
Most swap out the adapter for a standard E61-style dispersion screen. This allows more headspace and improves the loose grounds extractions considerably. On a lark, I tried the adapter coupled with the La Marzocco triple basket, figuring that the reduced head clearance of the adapter and the extra clearance of the triple might cancel each other out. It worked pretty well at 19 grams instead of the usual +22 grams.
The other downside of the adapter is its "ledge". You can see a lighter ring in the picture above. That's the portion that extends beyond the grouphead seat; unfortunately it accumulates grinds.
Bottom line: Nice try, but this thing belongs in the drawer next to the single basket and stock plastic tamper.
Postby rfc on Tue Aug 30, 2005 6:22 pm
So if I understand correctly, I should replace it with the smaller "water jet breaker" alone, or do I need the "dispersion screen" too? As you can tell, I know about as much about this as I do shutting down a nuclear power plant in an emergency. :?
rfc
Postby HB on Tue Aug 30, 2005 9:03 pm
Correct, the water jet breaker and E61-type dispersion screen together serve the same purpose as the adapter.
Return to Espresso Machines
