by RayJohns on Wed Apr 20, 2011 3:00 am
As mentioned, what you want is silver solder. Technically, it's considered silver brazing. Be careful, because hardware stores do sell a "silver solder", which is used for plumbing, etc. However, this is different than true silver solder, such as the type used in jewelry work and/or the brazing of metals.
Also, as mentioned, the plumbing type solder has a lower melting point (not to mention, typically a lead content), which may not make it the best choice for use in your espresso machine (although it probably would work - just not as nice as silver soldering/brazing would).
Silver solder comes in different alloy percentages. The lower the silver percent, the higher the melting point (if I recall correctly). It's also sometimes referred to has hard/medium/soft silver solder in the jewelry world. Due to the different melting points, you can use it to braze joints (such as on rings, etc.) next to one another. For example, if you have to solder two areas, you would do the first using hard solder, which has a higher melting point. Once you effect that connection, then you would step down and solder the joint next to it, using a lower temperature silver solder. This allows you to solder the 2nd connection, without as much risk of melting the previous joint next to where you are working.
If you have a welding supply place in town, check them out. They should have what you need. As mentioned, it will probably take a gas torch. You might be able to use propane also. Normally the silver alloy content is around 45% or 56% or so. Either of those will produce a very good brazed connection. Be sure the surfaces are perfectly clean (even free from the oils of your fingers) and use flux. The silver will seek the heat, so torch placement is important. Check YouTube for videos on how to silver solder.
Good luck!
Ray
