What is PS Bar and PT Bar Pressure
- JK
My Fiorenzato Bricoletta HX espresso machine's label has two Bar ranges 2 PS Bar and 3 PT Bar
I'm wondering what that stands for.. I can't find it doing an google search..
I'm trying to understand if I am adjusting my Bar pressure too high..
I'm at the fluctuating range of 1.8-2.0 now..
This is a pic of my gauge
My E-61 Group Temp. is 210°
I have read a lot of people have there E-61's at 214° and 1.1 Bar
I'm not sure if the gauge is off or I just need guidance..
I'm on a Mission from God!
PS and PT refer to the pressure equipment directive (PED) which is the European law regarding pressure equipment.
PS is the design pressure and is the maximum pressure the equipment is allowed to operate at. Safety devices must be set in such a way that this pressure is not exceeded during normal operation.
PT is the test pressure. It is the pressure used for the hydrostatic pressure test and should be at least 1.43 times PS
- erics
- Supporter ★
You are waaaaay too high. A reasonable pressure for that machine is 1.00 bar max (when the heating element just turns off).I'm trying to understand if I am adjusting my Bar pressure too high..
For Walter - nice write up on European requirements. Did the "1.43 value" come from the document you cited?
Yes is does, Directive 97/23/EC Annex 1 par. 7.4erics wrote:For Wally - nice write up on European requirements. Did the "1.43 value" come from the document you cited?
- JK (original poster)
What temp should I want my group head to be?
At 1.1 Bar its runs at 195°
- erics
- Supporter ★
I would say 196-197 F but that is really a user preference.What temp should I want my group head to be?
The issue I see is that your grouphead temperature (how are you measuring this?) and your 1.10 bar (maximum?) boiler pressure do not correlate. Something is amiss with either your pressure gage or your temperature instrument.
