Well I suppose my original rambling idea was how much difference does 10 degrees F make to the taste?
A huge difference. Depending on the coffee, one degree will make a big difference.
Stick all the gear in cabinet somewhere. Pull a shot, sour, up the temp 2 degrees and repeat until it goes bitter (or lower if you start bitter until it goes sour) then reduce 1 degree at a time till it hits the sweet spot. That is, provided the beans are good, grinder adequate, technique good, dose proper, etc... Do not worry about what the gauge or PID reads, worry about what you taste and adjust accordingly. Then you can start playing with dose and extraction rates/volumes to fine tune that particular coffee.
