by karl_a_hall on Mon Jan 31, 2011 7:29 pm
Yep, d92 is about right, s2 means semi-auto (not programmable like the 'A') two group. Parts are easy to come by, pretty standard stuff through espressoparts.com (they also have diagrams, which are uber helpful if you can't figure it out by looking).
Plug it in with it attached to a water supply (positive pressure makes diagnosing a little easier IMHO), then turn the power switch to position 1 (everything but heating elements get power), and see if it autofills (it maybe just maybe already be full enough to not kick in autofill, check the level sensor, use a flashlight to help see the meniscus if your glass is dirty). Then wait for the auto fill to finish, then try out your groups and hot water tap. If it all seems to be working and the boiler is full (full as in 2/3s full, if it over fills things will go wonky, and that just means your level sensor is gummed up which can happen easily on older machines that were not well taken care of... be careful pulling that out of the boiler, you can break them pretty easily), then switch it to position 2 and wait to hear the heating elements kick on. As it warms up you will get some water out the vacc breaker, but other than that look for leaks as it builds pressure. See if the heating elements kick off once you get up to pressure (i.e. is your pstat working), if you see it go over 1.7 bar, then shut it down and take a good look at your pstat. If things don't work at any point, solve the problem (or attempt to), before continuing onto the next step. If you can't fix it, then you know at least the beginning of the problems you will have to solve when you tear it apart.
As far as rebuild... just take it all apart, and take 2x as many photos as you could ever dream of having to take. label all wires and plugs with tape and a good description of where they go. Save screws in bags labeled as to what they attach. Don't leave chrome too long in the acid bath. Don't put any electronics (including heating elements into the acid bath). Take everything as far apart as possible before putting it in the acid bath. Most parts should be totally fine, maybe a valve or some gunk blocking up your gicleur would be the expected problems I would be especially keen to find. The pump could be bad... just don't run it w/o water for very long.
So there is my long and rambling list of beginners advice. Hope some helps. Feel free to send me more PMs if you have specific questions, or even just post them here to increase the collective knowledge. I made it through my rebuild of almost this exact same machine with the help of the folks here. It is a good place. The search function is your friend.
