Water softener basics and recommendations?
Does anybode have experience with water softeners, and can anyone give me crash-course in the basics of these things? What units do you recommend?
- networkcrasher
How hard is your current water supply? Have you read Jim Schulman's Insanely Long Water FAQ?
- arcangel6
Hi,
I am about to plumb my new machine (Brewtus III-R) and just placed an order for the item listed below after communicating with Chris Nachtrieb of Chris Coffee. He was extremely helpful in my decision making. I live in an area where the water is pretty hard. I'd highly recommend checking with Chris.
Regards,
Joe
Item #WS6000SYS - Commercial Rechargeable Water (6 Liter)
Regards,
Joe
- sweaner
Joe, why did Chris recommend this setup over this less expensive setup with the replaceable cartridges?
http://www.chriscoffee.com/products/hom ... enersystem
Scott
LMWDP #248
LMWDP #248
The big advantage of this one is it's rechargeable which I guess is also it's downside. Now that I've found the cartridges for $8 and figure with the water usage of my machine, I'm glad I got the smaller one.
Ira
Ira
- networkcrasher
One can recharge the smaller softeners too, it's just a bit more work.
- Rybolt
Any recommendations for people with pour over machines?
Do most people just blend distilled with filtered tap water to soften?
Not sure about most people but that's what I'm currently doing.Rybolt wrote:Any recommendations for people with pour over machines?
Another option from the Insanely Long Water FAQ:
Use Volvic or Crystal Geyser Natural Alpine water in your home espresso machine. They have formulations that won't scale, but which still taste OK for coffee.
- Rybolt
Wow, that's a system. Did you consider getting a water softener for your whole house, since your water is so bad. you could have benefited from it more than just your espresso.arcangel6 wrote: He was extremely helpful in my decision making. I live in an area where the water is pretty hard.
I have a pourover MiniVivaldi. Water softness is CRITICAL for this machine since it has a sealed steam boiler and heater unit.Rybolt wrote:Any recommendations for people with pour over machines?
My water hardness is around 150ppm. I do a double filtering using a Brita filter from the fridge and then a reservoir filter/softener from BestCup in Germany (came with my Vivaldi). I change both filters every 2 or 3 months. This brings the hardness down to 50ppm.
If my water hardness was higher that 150ppm, I'd probably just get a 20L bottle of RO water and mix it with tap water to get 50ppm.
"Disclaimer: All troll-like comments are my way of discussing"
