Water, Scaling and Descaling with HX espresso machines? - Page 8
- mrgnomer
I did find opening up the steam wand vented pressure to below pressurestat set. So I imagine the steam wand needs to stay open until the pump shuts off after the boiler water reaches it's set level.
Thanks again.
Thanks again.
Kirk
LMWDP #116
LMWDP #116
- mrgnomer
Over filling wasn't the problem. Draining as much water out of the boiler after the overfill then filling it back up is when the machine acted strangely.Compass Coffee wrote:I always take the steam tip off when over filling during boiler descaling just in case. This way there's never a problem. And kill the pump during over fill as soon as liquid is flowing from the steam wand simultaneously closing the steam wand.
Kirk
LMWDP #116
LMWDP #116
This is really testing my memory banks, but I seem to recall some discussions (probably on CoffeeGeek) that were along the lines of filling the boiler with descaling solution without overfilling, but then tilting the machine to drop the scale on the waterline below the solution. I realize that you'd have to tilt the machine at least twice (Right-side up and Left-side up) if not four times (Front-side up and Back-side up) -- any dangers in doing this? I know I'm being pretty lazy.
Thoughts?
Thoughts?
- HB
- Admin
If you have an assistant to help you with the maneuver, it's worth a try. Tilting would fool the autofill into overfilling, especially if the probe is located on the left/right; it may not work as well if it's dead center. The Ulka E5 vibratory pump puts out ~600mls in 1 minute at ~1 bar, so you could calculate how much the level rose by timing how long the pump runs (left as an exercise for the reader).
- cannonfodder
The scale should build up at the water line and below for the most part. You could slightly overfill the boiler but not top it off. Personally, I would fill the reservoir with descale solution (and an empty boiler), turn it on and let it fill as normal. Once full, disconnect the water level probe (one wire) and power it back on for 10-12 seconds, then power it off again. Then reattach the level probe wire, plug the machine back in (you did unplug it before you started sticking your hands inside the machine, right?) and let it heat and soak.
That would get the solution above the normal waterline and descale the majority of the deposits. Then flush, a lot, to clean it out and prepare it for use. The HX is even easier to descale, just lift the lever and let it fill with descale and sit, then flush.
- TimEggers
First I want to thank you gentlemen for such an informative discussion. I used this information to descale my four-month-old Anita. She's been acting a little strange lately. I had been dreading doing this just out of intimidation. I suspected the Anita had been getting hard water due to our homes water softener running out of salt.
I decided an active descale was needed. I did things a little differently in that I did both the HX circuit and the boiler during the same session. Basically I brought the machine up to operating temps. I filled the water tank with a strong Cleancaf solution (its what I had). I then let the boiler run water through the hot water tap until the water coming out was a deep blue (yeah the Cleancaf was strong). I then tilted the unit to overfill the boiler. I then ran some water through the HX until it too came out blue. I then let the unit sit for about an hour (it was late and I didn't know if leaving Anita like that overnight was a good idea). Is it?
After an hour I began to flush everything. I overfilled the boiler a few times and flushed. I then proceeded to flush the HX. I flushed everything (including the steam wand) until the water came out crystal clean (about two tanks).
The Anita is running great so far today but I noticed that the boiler ran .2 bar or so higher then before the prescale. Why is that? Is it due to leaving the machine on while being overfilled? I adjusted the pstat back down and she's running great so I don't think I damaged/hurt anything. I did before the descale adjust the boiler pressure up for better steaming (about .3 bar). So why was Anita running hot after the descale?
All in all it went well and I got a lot of gunk (and green water) out of the boiler. Plus some granule gunk from the HX. Yes I think Anita was getting some hard water for the past month or so. Anyway just wanted to say thanks and offer my appreciation and a few questions.
Tim Eggers
LMWDP #202
LMWDP #202
First of all I must apologize for my pour English skills - I hope I can make my self understood anyway.
I have a few questions.
I have bought a used BFC La Valentina Junior.
It is 5 months old but I don't think it has been running on soft water.
So I need to give it a real overhaul but before starting I will just make sure that I have understood it the right way.
I'm not that good with electronics so I hope to be able to do this without grounding the autofill?
Exactly why is it the autofill has to be shut when cleaning the HX
First I descale the Hx:
- Warm up the machine.
- Fill the water reservoir with the citric acid solution.
- Turn the pump on to flush the grouphead (E61).
- Leave it, with the heat on, for 10 minutes and flush again.
- Repeat 4 to 6 times.
- Refill the water reservoir with clean water.
- Flush thoroughly.
Then the boiler:
- Turn it off and drain it for water through the hot water tap while tilting the machine.
- Fill the water reservoir with the descaling solution (Citric acid).
- Turn the machine on again.
- Tilt the machine left/right to descale instead of disconnecting the autofill.
- Let it sit for hours.
- Repeat this with clean water in order to rinse it through.
If this is not correct please let me know. I'm really a newbie to this
Thanks
Martin
- Flush thoroughly.
Then the boiler:
Thanks
Martin
- HB
- Admin
NB: These descale instructions are for removing light scale as part of preventative maintenance, not removing heavy scale, which requires stronger acids handled by a qualified repair technician. Check the E61 mushroom to determine the extent of the scale buildup.VWespress wrote:I have bought a used BFC La Valentina Junior.
Your steps are about the same as Ian's Simplified HX descale.So I need to give it a real overhaul but before starting I will just make sure that I have understood it the right way.
The autofill sensor is grounded when descaling the HX to prevent an inopportune boiler refill from drawing descaler into the steam boiler. OTOH, it would not matter if you plan to descale the steam boiler and do it after the HX descaling.I'm not that good with electronics so I hope to be able to do this without grounding the autofill?
You do the opposite when descaling the boiler. Heavier scale forms at the boiler's water level. Momentarily disconnecting the autofill sensor forces the boiler to fill above its normal fill level, covering the scale with descaler solution. Tilting the machine can also force the boiler to fill higher than normal, depending on the sensor position.
As an aside, some espresso machines have an easily adjustable autofill sensor. A quick twist of the one below (f) on the Cimbali Junior DT1 will change the sensor's level.
The DT1 also has convenient boiler drain (d), which eliminates the need to drain the boiler through the water tap. Descaling is a lot easier when the manufacturer designs the machine with it in mind.
Thanks a lot!
I will absolutely give it a go tomorrow afternoon!
The "mushroom'" is actually not looking that bad at all but it doesn't sound too good!
Once again - Thanks
Martin
Once again - Thanks
Martin
- Ozark_61
Whew - that took a while. I finally got around to the local brew supply shop here and bought some citric acid. Descaling can be a pita! That, and having the temp drop too much when filling with descale solution, vacuum breaker falling, and then showering the inside of the machine with descale and subsequent shorting out mains current made for a long evening / morning!
Benefits? Looks like my giotto's steam wand is no longer drippy without a hard tightening and the lever is much smoother too boot.
I noticed that while soaking the boiler and flushing the HX - the water went from dark green to light blue/green after several flushes of the hx through the gh. Is that an indicator for decreasing levels of scale? Also, I noticed metal particles in the water in the flushed water. With a strong overhead light, I could see the tiny particles glittering through the water in the flushing cup. Is this normal / harmful / temporary?
Geoff
ps - clean your in-tank water softeners (link).
PPS - I just thumbed through the old posts about descaling and realized I shouldn't have backflushed the machine per Jim's comment that a squeaky clean machine should not be introduced to an alkaline detergent. I had more flecking (did look like chrome bits) before the backflush, so I don't think it did much harm.
I would recommend adding that point to the HX descaling instructions!
Geoff
