Water, Scaling and Descaling with HX espresso machines? - Page 4
- barry
if you're using a citric acid descaler, just keep flushing until the water no longer has any sourness. it takes a whole lot of water to flush.cannonfodder wrote:Ironically, I think the hardest part is flushing out the descale liquid. I ran two reservoirs of clean water through the boiler and HX line. I kept flushing until the water was nice and clear, then a couple of additional flushes for good measure.
I just wanted to publicly thank Another_Jim and everyone else here for the instructions on descaling. I did both the HX and boiler on my Tea and everything went just fine (I think). I'm having one problem, but it could be a choice of a few things (I'll post a new thread on it so I don't hijack this one).
I've posted 5 new threads for problems I've had with my Tea since I've owned it over at CG. Each problem was correctly solved by Another_Jim, so I am truly thankful to you for all that you offer on these boards. There were others who chimed in on the threads, but Jim was the guy who cracked each case. So just in case I'm not making my point clear......THANK YOU, THANK YOU, THANK YOU!!!!!!!!
For anyone who hasn't descaled and owned a machine for a while, I highly recommend it. I am very surprised at how much better the water tastes. It's still too early to judge shot quality because I'm having the problem I mentioned above, but I'm sure once I get everything back in order it will be better.
One thing that I did notice was that after descaling my vacuum breaker pops up without making a big water mess. I was having a lot of wiring problems because it would soak the inside of my machine before popping up. Now it just hisses a bit, makes some gurgling noises, and pops up with only a few drops coming out. The water in Japan is VERY soft, so there wasn't much scale that came out. But it's nice to know that things are cleaned up in there.
- HB
- Admin
Added for reference, before/after scale buildup on an E61 "mushroom":
No scale buildup
See Sputtering e61 & HX scale build-up - Cured! for more details
No scale buildup
- Compass Coffee
Plan to stop by a local brewers supply tomorrow to pick up some citric acid. Been running the Bricoletta with about 7grain/120ppm filtered water for 8 months now so figured I'd best quit putting off descaling before scale becomes a problem! I know water is a bit hard but it tastes good so haven't bothered with a softener.
I'll add my thanks to Jim for great descaling directions and the rest who've added to this thread. Makes the thought of descaling a direct connect HX mucho less intimidating. In fact should be a piece of cake. Already verified the auto-fill sensor location and tested. Now that's a wire you wouldn't want to fall off! Don't plan on adding a T to the supply line, figure I'll simply slide the John Guest connected line off mains line and put it in a jug of citric acid solution placed on a shelf above the Bric'.
Probably wait to do the descaling 'til the Barksdale pstat I ordered last Friday arrives. Install it while waiting for boiler descaling to do its work.
Mike McGinness
- Compass Coffee
Might add descaler backflushing to this section as suggested by tech I talked to at Chris' Coffee. (We talked over intended procedure once I convinced him I wouldn't hold them liable for any problems arising from descaling a direct connect rotary HX. ) Also since I pretty well know the Bric's auto fill tendencies didn't ground/disable auto-fill, simply made sure boiler was full to normal first by forcing fill via hotwater purge.another_jim wrote:Descale the HX like you descale a home machine:
-- ground the autofill wand (see above)
-- fill the tank with the descale solution.
-- flush the group with four ounces worth, wait 10 minutes, and repeat.
-- repeat this 4 to 6 times.
-- refill the tank with water
-- restore the autofill
-- flush the group till the taste is gone (start with 1 quart before tasting). If anyone has one with a big honking HX like the Cimbali's, please jump in with revised quantities.
FWIW the rotary Bricoletta sucks the solution from a container no problem lack of line pressure. No need for a line T, once pressure relieved John Guest fitting slides off easily. The only bad part of letting the descaling solution just sit there doing it's work in the boiler is now won't be able to pull a shot for hours!
Mike McGinness
- another_jim
Good idea, but there is a gotcha. The inside of many groups are, alas, chromed. The E61 is one of these. Eventually the chrome peels little by little and ends up in the grounds, so it's no big deal. One person decided to descale, then backflush. Detergent is highly alkaline, so he gave his group a super foamy bicarbonate and peroxide style rinse which took all the chrome off in one fell swoop. Make sure not to telescope descaling and cleaning into one session (the home machine compound that does both has no acid, but uses ultra-alkaline detergents)Compass Coffee wrote:Might add descaler backflushing to this section as suggested by tech I talked to at Chris' Coffee.
Jim Schulman
- Compass Coffee
Post descaling both the HX and boiler direct connect Bricoletta thoughts or tips:
1) Initially drain the boiler as you would for shipping then fill with descaling solution to normal fill level letting it come fully up to temp. Draining first will help ensure better strength descaling solution in the boiler than just flushing water out and descaling solution in.
2) Flush descaler through the group and then backflush the group with descaler before overfilling the boiler. Hot descaling solution works faster than cold per techs I talked to. Once boiler overfilled not advisable to try and fully heat boiler.
3) Now overfill the boiler with descaling solution until it runs out the steam wand as liquid. When over filling the boiler it'll dump the boiler pressure and drop the vacuum breaker stem, so hold it up with needle nose pliers to greatly minimize any descaling solution getting inside the machine's innards. A bit may still come out so have a towel wrapped around it. Once you turn off the machine and close the steam wand ok to let the vac stem drop.
4) While the machine is sitting there letting the descaling solution do its thing periodically turn the machine back on for 15 or 20 seconds or so to keep the descaling solution in the boiler good and hot. But not long enough to force water out the vac breaker. The Bric's boiler will sort of start to rumble before that point is reached. Let the rumbling/heating continue and pressure will build forcing descaler out. At this same time solution backflush again since it's not a closed system holding the solution like the HX path or boiler (makes sense to me anyway).
5) To flush descaler from the boiler first open the water wand then turn on the machine and hold up that vac breaker stem! (And make sure the auto-fill sensor has been put back on, oops.) After enough descaler has dumped from the boiler to engage auto-fill ok to let the stem down and now close the water wand and let the boiler come up to full pressure. Now turn off and drain the boiler same as step 1. (on the Bric' tipping the machine towards the right, the Bric' that's the hotwater feed side of the boiler). Draining first will greatly reduce the amount of fresh water flushing needed.
6) After filling to normal lever and flushing about a boiler's worth fresh water I let it come up to full temp and then over-filled boiler with fresh water. Figured since the worst scale is at the water line and descaling solution had completely filled the boiler made sense to completely fill with fresh water. I actually did this three times, each time draining to normal fill level and coming back up to full temp before next over-fill. The third time didn't seem to get any additional loose scale particulates.
Descaling a direct connect HX machine really was easy thanks to the directions from those who have gone before and taken the time to document the procedures!
Interestingly as other's have mentioned my lever action is now smoother and totally squeak free quiet. Smoother and quieter than even when new! Don't need no stinkin' food grade grease.
Mike McGinness
bringing a good thread back alive - is it ok to leave the machine on while the boiler sits with citric acid solution? only thing ive noticed is that when it cycles to heat up, it goes past the stock 1.1bar quicker, stops at around 1.3-1.4bar, then begins its drop. id assume this is b/c there is no steam buffer in the tank, its all water. hope its ok, i thought it would be good to help keep the machine hot.
ive already filled and have it sitting, and have flushed the hx while i started waiting. too bad this isnt something where you can see the results!
- cannonfodder
I thoroughly overfill the boiler when I descale, water pumping out the steam wand for several seconds. When it heats I get water spitting out of the vacuum breaker valve. I put a towel around the breaker valve to soak up any spatter and keep another handy just in case it gets to wet.
You don't want water dripping off the boiler and onto the electronics. On my Isomac, the level box and circuits are under the boiler and behind a heat shield. Not the best design in my opinion.
i overfilled the boiler as well; i let the water come out of the water sensor hole, and when the boiler was filled, the vac breaker (?) and pressure relief valve(?) shot watery steam out of their relief holes as well. put the water level sensor back in, and let it sit for about 2 hours.
i kept the machine on since it held the heat nicely that way, but did cycle a LOT. i dont know if its b/c the panels were removed or b/c there was no steam 'headspace' to help it maintain equilibrium. i think im going to insulate the parts on it, not only for wire protection from the heat, but to help the thing from cycling so much. with such a small deadband (well, 1.5bar is tight to me!) it cycles too much, and i dont want electronics failing.
flushed it about 3 tankfulls of tap water, then drained the boiler and filled and flushed with my filtered water line.
all in all the process was uneventful; blueish water came out of the grouphead (flushed that as well), and out of hot water wand. weird thing was some black stuff came out of steam wand, maybe some milk that got sucked back in? i do run the steam quite a bit after i froth, but maybe some still manages to get lodged. im happy to see the machine run so rock solid with all the cycling i just put it through, thats certainly good news!
only ran 2 shots after cleaning to lube the machine up, all seems to be working well.
