Javacat wrote:Can anyone say with absolute certainty that water hardness with a variation of a few grains makes a descernable difference in espresso flavor or body?
I believe that the relationship of water chemistry to espresso extraction is much more complicated than simply taking the two or three most easily obtained results off an analysis and trying to draw conclusions from them. Although it is certainly feasible to remove nearly everything from water, e.g. to demineralize it with techniques such as Reverse Osmosis or distillation, then to selectively add back in what you want from a veritable "buffet" of minerals and ions, this is not going to prove to be either cost effective or reasonable for most people.
Very soft water is the one type of water that, if I had it coming in from the tap, I'd consider adding in hardness. This is the situation one faces in much of the coastal Pacific Northwest. And I'm not sure if there wouldn't be some lower maintenance option to just adding back in calcium carbonate, but not having this problem myself I haven't studied it. If on the other hand your water is very hard and or tastes bad or both, there are simple things that one should try first in order to determine if a simpler, cheaper, lower maintenance solution makes the most sense. These would include cation softening and use of a carbon filter. I would not approach all water problems the same, and would not advocate starting out with RO water and then adding stuff back in, as there is probably a much easier and cheaper solution that will not scale up your machine very much, and produce equivalent results.
ken
