Water quality -plumb in options
Postby Bkeef on Sun Mar 27, 2011 2:31 pm
Im looking to plumb in a new machine. I've been pour over ala Brita for a while. I used an inexpensive test strip and it appears my hardness is about 3-5 grains. (50 ppm). According to the chart.
First question. If that's accurate that's the target from what I understand. Do I plumb up straight ?
If I do plumb up it would need to be something compact and easy to service. Everpure Claris looks good from posts. I know enough to be dangerous so I thought i would ask others for input.
Thanks
Brian
Bkeef
Postby Randy G. on Mon Mar 28, 2011 11:11 am
That does sound like pretty good water. You might want to place a carbon filter inline, if not for taste but also to act as a particle filter.
water hardness conversion
The Insanely Long Water FAQ
I am in the same boat, about to plumb a machine in, and am probably going to go with the system that Chris Coffee sells which is a softener (cat-ion) and carbon 10" filters.
Espresso! My Espresso!
Randy G.
Postby caffeinatedjen on Mon Mar 28, 2011 11:39 am
If you want to use a flo-jet, could you use a filter and just use your tap water in the water bottle instead of buying bottled water all the time?
caffeinatedjen
Return to Espresso Machines
