by shadowfax on Sat Feb 21, 2009 1:29 pm
That probably will cover it. according to the site, the maximum drawdown is 0.7 gallons. I assume that means that it can deliver 0.7 gallons before losing pressure. That number may well be a little higher given that the line itself has nearly adequate flow.
The Elektra Sixties A3/T1 boiler is 6L, and I would guess that it's probably only filled with about a gallon of water. Since you're never going to empty it all the way in normal usage, you should be safe. Just make sure you have an adapter to connect that to your setup between the filter and the pump. depending on what your pressure regulator is set to, you may decide to put it before or after the pressure regulator. In determining that, you want to make sure you get even inlet pressure to the pump during brewing. If it flutters during boiler fill, that won't matter.
Nicholas Lundgaard
